Author Topic: LED Color Changers  (Read 1775 times)
Offline Butthurt Tumbleweed
LED Color Changers
« on: Thu, 25 September 2014, 20:53:14 »
I have never owned a mechanical keyboard and am hoping to get started with a tt esports Poseidon, but I plan to build a computer soon with a glowing purple theme. Poseidons only come in blue LEDs apparently.
So of course LED color changers for mechanical keyboards (basically a colored plastic piece that fits over the LED) caught my eye.
But would a purple color changer look purple on a blue LED? or would it look more blue? would a red cover make a blue LED look purple?
« Last Edit: Fri, 26 September 2014, 17:37:01 by Butthurt Tumbleweed »
Re: LED Color Changers
« Reply #1 on: Thu, 25 September 2014, 20:59:20 »
it looks like you need help with led color changers
Offline FrostyToast
  • Litshoard
« Reply #2 on: Thu, 25 September 2014, 21:01:06 »
Looks like you want a keyboard with purple LEDs  :))
Although from a serious view, don't use color changers. They don't have great compatibility with keycaps at all.
Quote from: elton5354
Offline frosty
  • jukebox hero
« Reply #3 on: Fri, 26 September 2014, 12:36:03 »
Get red led changers because blue + red = purple. Or am I insane?
« Reply #4 on: Fri, 26 September 2014, 12:58:18 »
I think that only works for paint not light.
« Reply #5 on: Fri, 26 September 2014, 17:39:35 »
The reason I'm trying to get the Poseidon is the price. I think the color changers are still a good idea (if I change my computer theme, color changers are cheaper than a new keyboard)
Are there other keyboards at around the same price with white LEDs? (and I NEED my keypad )
« Last Edit: Fri, 26 September 2014, 17:43:32 by Butthurt Tumbleweed »
Offline ADFX_Pixy
« Reply #6 on: Sat, 27 September 2014, 05:25:19 »
If you're planning to build a PC you should focus your budget on the parts first. You can get away with using a subpar keyboard you have lying around until you have enough money to get a nice keyboard.
CM Storm Quickfire Stealth Cherry MX Brown
Mechanicalkeyboards.com MK 2016 Cherry MX Brown
