Author Topic: KT and SS  (Read 3359 times)
Offline henz
  • What?
KT and SS
« on: Fri, 26 September 2014, 03:21:09 »
Im interested in some KT and  SS profile caps: http://keycapsdirect.com/key-caps.php
but i have no idea where to get them.
Are there any  caps like this out in the loop(GB or vendor)? Would be cool if someone has some pictures to post.
Offline jacobolus
Re: KT and SS
« Reply #1 on: Fri, 26 September 2014, 03:26:41 »
I’m going to hopefully be able to play with some SS keycaps when SP gets around to making some as a one-off in ~4-5 weeks. (I think they’re currently pretty backlogged. :shakes fist at Granite set:) I’ve never seen a picture of them online.
KT is not available for Cherry MX. (I think it’s either buckling spring keycaps, or some kind of rubber dome? It says “1 MOUNT STYLE AVAILABLE - ROUND SLEEVE”)
Offline henz
  • What?
Re: KT and SS
« Reply #2 on: Fri, 26 September 2014, 03:38:45 »
So the SS keycaps, can i get some too in that case wher? Or was it a GB?
Offline jacobolus
Re: KT and SS
« Reply #3 on: Fri, 26 September 2014, 03:41:45 »
You can email SP directly and order a set. Should run you $100–200 for a set of blank caps, depending.
Re: KT and SS
« Reply #4 on: Fri, 26 September 2014, 04:31:18 »
KT profile looks like a nightmare  :confused:
Offline jacobolus
Re: KT and SS
« Reply #5 on: Fri, 26 September 2014, 04:33:37 »
Offline bazh
Re: KT and SS
« Reply #6 on: Fri, 26 September 2014, 04:52:13 »
KT reminds me of an old Cherry keyboard with uniform cylindrical keycaps profile, cant remember the name tho
HHKB Pro2 white
Newbie again
Offline henz
  • What?
Re: KT and SS
« Reply #7 on: Fri, 26 September 2014, 05:30:45 »
By the way, cf. http://geekhack.org/index.php?topic=63052
Yup Read the thread before. Just gotta get one of each to see which i like the most :)
So i think id be sending a email to SP when i feel its time :)
