Author Topic: Bluetooth keyboard or add-on  (Read 2504 times)
Offline zippox
« on: Fri, 26 September 2014, 07:44:40 »
A friend at work has the Realforce 104UB and was wondering which mechanical keyboards are bluetooth or if there is a way to make his bluetooth. Ideas?
Offline esoomenona
  • Gnillort?
« Reply #1 on: Fri, 26 September 2014, 08:20:24 »
« Last Edit: Mon, 21 September 2015, 11:56:28 by esoomenona »
Offline frosty
  • jukebox hero
Re: Bluetooth keyboard or add-on
« Reply #2 on: Fri, 26 September 2014, 12:35:09 »
Short mini-b to usb cable to a bluetooth adapter, does it work? :O
Offline esoomenona
  • Gnillort?
« Reply #3 on: Fri, 26 September 2014, 12:37:16 »
« Last Edit: Mon, 21 September 2015, 11:19:48 by esoomenona »
Offline ynrozturk
« Reply #4 on: Fri, 26 September 2014, 12:50:14 »
Filco Minila is the only one I am aware of. Would never want that space bar, though.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
« Reply #5 on: Fri, 26 September 2014, 12:53:29 »
kbtalking pro is bluetooth as well.
http://kbtalkingusa.com/
« Last Edit: Fri, 26 September 2014, 12:55:53 by dorkvader »
Offline SonOfSonOfSpock
« Reply #6 on: Fri, 26 September 2014, 17:48:40 »
Here is a list from reddit that has both adapters and native wireless mechanical keyboards: http://www.reddit.com/r/MechanicalKeyboards/wiki/wireless-mechanical_keyboards
Offline xuanwumen
  • * Commercial Vendor
    • EZKB
« Reply #7 on: Sat, 27 September 2014, 10:53:32 »
noppoo choc mini 84-2m, wired/wireless modes.
NIZ KEYBOARDS VENDOR
« Reply #8 on: Sat, 27 September 2014, 11:21:32 »
Filco MJ2 and miniLA both have bluetooth versions.
