Author Topic: Ducky Shine 3 won't turn on - any ideas?  (Read 4484 times)
Offline faceyourfaces
« on: Fri, 26 September 2014, 18:36:33 »
One of the LEDs died on my Ducky Shine 3 so I decided to open it up to look at the PCB and see where I would have to solder to replace it with a new one. I unplugged the wire on the keyboard connecting it to its Micro USB port to get a better look and plugged it back in. Now, whenever I plug it into the Micro USB cable connected to my PC, it won't turn on. Any ideas of what went wrong?
78143-078145-1
Offline Owntrolf
Re: Ducky Shine 3 won't turn on - any ideas?
« Reply #1 on: Fri, 26 September 2014, 19:08:16 »
are you sure you plugged teh usb in the keyboard right
« Reply #2 on: Fri, 26 September 2014, 19:29:39 »
Yeah, I plugged the USB into the keyboard.
Offline esoomenona
  • Gnillort?
« Reply #3 on: Fri, 26 September 2014, 20:28:01 »
« Last Edit: Mon, 21 September 2015, 11:18:54 by esoomenona »
« Reply #4 on: Fri, 26 September 2014, 20:57:51 »
Try turning the little black connector connecting to that daughterboard where the micro USB port is over?
I've tried that as well.
Offline asdfjkl36
  • blue shirt guy
« Reply #5 on: Fri, 26 September 2014, 23:18:04 »
Well i just took a look at my Ducky Shine 3 and the black connector is upside down, as mentioned above.
The red cable should be on the bottom, not the top.
Offline esoomenona
  • Gnillort?
« Reply #6 on: Fri, 26 September 2014, 23:27:50 »
« Last Edit: Mon, 21 September 2015, 11:18:41 by esoomenona »
« Reply #7 on: Fri, 26 September 2014, 23:55:58 »
Thanks for trying to help. Unfortunately pushing the cable in further and reversing it on the daughterboard did not fix the issue.  :(
« Reply #8 on: Sat, 27 September 2014, 00:00:52 »
I have noticed that the board gets hot right around where the power is plugged in but does not work.
Offline asdfjkl36
  • blue shirt guy
« Reply #9 on: Sat, 27 September 2014, 00:27:05 »
have you tried another usb cable / another usb port on your pc?
« Reply #10 on: Sat, 27 September 2014, 01:08:08 »
No, but apparently reversing the polarity of the power cable can kill the board, which is what I believe happened to mine unfortunately.
Offline frosty
  • jukebox hero
« Reply #11 on: Sat, 27 September 2014, 02:37:38 »
Think you killed the controller by pushing the connectors in the wrong way :(
« Reply #12 on: Tue, 30 September 2014, 06:13:22 »
