Author Topic: White or Black  (Read 3175 times)
Offline Owntrolf
White or Black
« on: Fri, 26 September 2014, 21:17:56 »
The Massdrop for the Vortex PBTPOM is up but I'm not sure what color I should buy
Curently using the standard keycaps on a Ducky 9008 with the exception of a POM spacebar
https://www.massdrop.com/buy/vortex-backlit-doubleshot-pbt-keycaps
Offline Michael
  • Formerly Bro Caps
Re: White or Black
« Reply #1 on: Fri, 26 September 2014, 21:33:37 »
Offline Owntrolf
Re: White or Black
« Reply #2 on: Fri, 26 September 2014, 21:36:07 »
aintnobodygotdatkindofmoney
Offline heedpantsnow
  • Old enough to know better
Re: White or Black
« Reply #3 on: Fri, 26 September 2014, 21:38:31 »
Blite or wack?
I'm back.
Offline Owntrolf
Re: White or Black
« Reply #4 on: Fri, 26 September 2014, 21:43:17 »
I have no idea how white PBT will look with green backlight
Re: White or Black
« Reply #5 on: Fri, 26 September 2014, 21:59:50 »
If you're not using white backlight get the white. I think it looks cooler.
Offline mogo
Re: White or Black
« Reply #6 on: Fri, 26 September 2014, 22:01:52 »
My advice is to clash with whatever the base color of your keyboard is (most likely black). I think green backlighting on green keys might look pretty killer. Green LEDs tend to be pretty bright, I think it'll work.
Offline Owntrolf
Re: White or Black
« Reply #7 on: Fri, 26 September 2014, 22:19:37 »
Cant really do that since theres like no Green PBT POMs so Ill probably be getting white ones
« Last Edit: Sat, 27 September 2014, 09:23:19 by Owntrolf »
Offline kitsun8
  • In need of some cash
Re: White or Black
« Reply #8 on: Sat, 27 September 2014, 08:35:47 »
For green backlight i'd recommend black keycaps because think razer (i'm not a razer fanboy, but the green black does look pretty cool imho) white would look to bright i would think
Offline spOOfy
Re: White or Black
« Reply #9 on: Sun, 28 September 2014, 03:02:52 »
From one of the comments:
"A word of advice, the white keycaps have a significant amount of bleeding, and even more so if you have them on a keyboard with LEDs on the bottom. Had I known this, I would've gone ahead and went with the black ones, which don't appear to bleed at all."
Offline jameslr
Re: White or Black
« Reply #10 on: Mon, 29 September 2014, 13:29:59 »
Buy both
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: White or Black
« Reply #11 on: Mon, 29 September 2014, 15:31:53 »
White. Definitely
Offline mogo
Re: White or Black
« Reply #12 on: Tue, 30 September 2014, 00:24:02 »
agh i mistyped. I meant green LEDs under white caps. :P
