Author Topic: Some questions about Korean customs and GON TKL  (Read 2783 times)
Offline uprock7
« on: Fri, 26 September 2014, 22:07:18 »
Hey all, so Im interested in getting a Korean custom keyboard but I have a few questions before I commit hundreds of dollars towards getting one.
1. How do the LZ's compare with the GON keyboards in terms of case quality, pcb design, programability and feel?
2. How good are the LZ/GON keyboards for gaming?
3. How well do the korean customs work with mac osx?
4. Are keycaps all the same height?
Ducky Mini (2014), Filco Magestouch 2 w/browns, Das Pro 3 w/browns (retired)
Re: Some questions about Korean customs and GON TKL
« Reply #1 on: Fri, 26 September 2014, 22:19:49 »
LZs are a lot heavier, and people seem to like the case itself a little better, but GONs latest PCB, the NerD.2 is probably one of the top 3 to ever come out of Korea. (My personal top 3 list is 356 CL, NerD.2, and KMAC 2, in that order)
Kustoms are generally regarded as the best gaming keyboards. They also attract quite a bit of attention at LANs, if that's what you're into. You can put reds in your Kustom and literally become a god. *keyboards are not a substitute for actual skill
I think GON's boards work with OS X, but you can check his question thread to make sure.
Depends on what keycaps you put on them. Both boards come with feet for the case that you can install if you wish.
« Reply #2 on: Fri, 26 September 2014, 22:20:35 »
I recommend GON highly. I've got the parts to assemble one of his and just about every aspect of it is well engineered and spot on (high quality).
Traditionally apple support has been good on korean customs. The KMAC for example has media keys that only work in OSX, etc.
They aren't any worse for gaming than any other mech. Depends on your preference of course. The programmability and macro aspect might make gaming easier.
« Reply #3 on: Fri, 26 September 2014, 22:26:05 »
Oh yeah, I forgot to mention, GON's boards are FAR more easily available than any other Kustom right now.
Offline uprock7
« Reply #4 on: Fri, 26 September 2014, 22:42:24 »
I guess GON it is. I do like the look of the NerD.2. So my plan was to purchase the case and pcb at the same time, and then look into buying the switches, leds, resistors, diodes a few months later and then get the key caps some time after that. Do I need anything else?
« Reply #5 on: Fri, 26 September 2014, 22:51:23 »
stabilizers. GON sells them in his store.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #6 on: Fri, 26 September 2014, 22:54:26 »
if you want to see something cool, watch how fast GON lays some smd resistors:
« Reply #7 on: Fri, 26 September 2014, 23:28:34 »
I was thinking about getting a wider tip so I can do that too, but I don't know if it's worth it. Note that in order to do that you need to put solder on all the pads first anyway, so it might not even save you time. I think the most impressive part is how fast he picks them up with his tweezers. I can never get them out of the tape that quick.
Offline strict
  • TKL Zealot
« Reply #8 on: Fri, 26 September 2014, 23:54:18 »
Thanks for sharing! I would have loved to have had English subs for that though.
Offline kitsun8
  • In need of some cash
« Reply #9 on: Sat, 27 September 2014, 08:38:11 »
He is a freak :O
Offline kitsun8
« Reply #10 on: Sat, 27 September 2014, 08:39:12 »
Ayeee +1 for the GON :)) i'm waiting for my limited 60% black NerD PCB to arrive ;D
