Author Topic: Name of goldtouch cable anyone?  (Read 1791 times)
Offline vorpal
    • lugubrious fandango
« on: Sat, 27 September 2014, 04:53:13 »
I have a goldtouch keyboard which I've broken into its two halves, but I would like to position the halves further apart than the cable connecting them will stretch. Anybody have any idea the name of the cable connecting the two halves so I could buy a new one.
Cheers.
Re: Name of goldtouch cable anyone?
« Reply #1 on: Sat, 27 September 2014, 10:42:03 »
I don't remember there being any connectors so you would have to do a bit of work.
Open one half of the keyboard and count the number of leads in there. Then order a length of cable with (at least) that many leads.
Offline vorpal
« Reply #2 on: Sun, 28 September 2014, 06:00:51 »
Thanks for the reply. I'll take it to mean there isn't some standard cable. I guess that shouldn't be too surprising.
Some of the wires in the cable seem to be of a different thickness to the others so it might be more complicated than just, a cable with the same number of leads.
