Author Topic: Thoughts on the Vergo type.T MX/Alps compatible split custom?  (Read 5417 times)
Offline Zeal
    • Zeal Generation Inc.
« on: Sat, 27 September 2014, 11:56:13 »
Was browsing the Korean forums and randomly landed on these two pages. Found these two customs pretty interesting, since they use a SATA data connector to combine the two boards.
PCB designed by ZeFyr
Alps Cyrillic caps on the Vergo type.T
Blank black DSA
More images viewable from these two threads:
http://kbdlab.co.kr/index.php?mid=board_Lsno50&document_srl=501907
http://kbdlab.co.kr/index.php?mid=board_Lsno50&document_srl=515588
Somewhat OT, but landed on this page shortly after:
Apparently the image is from EnjoyClick. 3rd party MX housings in its entirety.  :eek:
http://kbdlab.co.kr/index.php?mid=board_Lsno50&document_srl=514958
Re: Thoughts on the Vergo type.T MX/Alps compatible split custom?
« Reply #1 on: Sat, 27 September 2014, 15:08:35 »
wow interesting!
We thought about what connector to use for the ergodox. Sata is as good as any I guess. There's lots of available cables and stuff. Note that they are absolutely not sending SATA or SAS data down that cable
I really like the lock light placement and the layout itself is pretty great. PCB appears to be of high quality, looks a lot like a GON with that ground plane.
Offline lkong
« Reply #2 on: Sat, 27 September 2014, 16:37:13 »
Actually someone on reddit has made a mounting plate for alps switch on ergodox.
http://www.reddit.com/r/MechanicalKeyboards/comments/2dsdkz/modification_ergodox_layer_3_plate_for_alps/
And also here is my MX blue (modifiers)/salmon alps (alphas) on ergodox.
« Last Edit: Sat, 27 September 2014, 16:39:04 by lkong »
« Reply #3 on: Sat, 27 September 2014, 22:34:51 »
All I know is that I needs it.  That's awesome.  Is it something that's well and done?
Offline WinterIsle
« Reply #4 on: Sat, 27 September 2014, 23:09:18 »
Zeal, for the 3rd party mx housings u mentioned probably are Gateron Switches if i'm not mistaken.
Offline feizor
« Reply #5 on: Sat, 27 September 2014, 23:33:59 »
Yep those look like Gaterons, 1RMB each, not sure about the key feel though. Good for lighting effects.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #6 on: Sat, 27 September 2014, 23:48:12 »
Something new and mostly different. I like. Just when I thought I'd be done with new boards for a bit. I want this for some reason.
« Reply #7 on: Sun, 28 September 2014, 00:05:21 »
why does that gh60 say "satan intention to do" on it?
Offline WinterIsle
« Reply #8 on: Sun, 28 September 2014, 00:29:06 »
The 1rmb promotion ended very quickly, some ppl said the linear one feel smoother than cherry mx.
I can be wrong about this, since I didn't had a chance to grab and try them out.
The price gonna be 1.5rmb for the next restock i think.
