Author Topic: Replacement desktop mic.  (Read 1862 times)
Offline Fragil1ty
  • Abre los ojos.
« on: Sun, 28 September 2014, 09:32:05 »
Hey guys,
So currently I have the Samson Meteor Mic and for some strange reason it receives loads of background noise, yet when I see other streamers use it and what not, there is no background noise what so ever, so I was thinking about either:
Getting the condenser version:
http://www.amazon.co.uk/SAMSON-Samson-Condenser-Meteor-Mic/dp/B00F9ATYWG/ref=sr_1_2?ie=UTF8&qid=1411914617&sr=8-2&keywords=samson+meteor+mic
Or maybe another good quality desktop mic? I just don't really know what are good desktop mics at the moment, I've heard the Blue yeti and blue snowball are really good, but they are a little bit too big for my set-up and what not, I like to have a mic that doesn't take up too much of my room and what not.
Any ideas?
你搞砸了
Offline Grim Fandango
Re: Replacement desktop mic.
« Reply #1 on: Sun, 28 September 2014, 10:27:09 »
I think the ones you mentioned are the most common recommendations.
Additionally, if you do not want to spend much for decent quality, and want something that does not take up too much space. Then something like the Samson go Mic is a great option.
http://www.samsontech.com/samson/products/microphones/usb-microphones/gomic/
« Reply #2 on: Sun, 28 September 2014, 11:03:23 »
your current mic seems to be about the same size as the blue snowball. i've heard it picks up sounds pretty well so you don't have to have it right in front of you.
Offline Fragil1ty
  • Abre los ojos.
« Reply #3 on: Sun, 28 September 2014, 14:52:34 »
I always thought the BS was a lot bigger, maybe I was wrong. I'll check it out and see what the current prices are and what not. Thanks dude.
你搞砸了
Offline epzy
  • HHKB Fiend
  • ded
« Reply #4 on: Sun, 28 September 2014, 15:24:10 »
Blue Snowball/Yeti is very good.
Offline jameslr
« Reply #5 on: Mon, 29 September 2014, 13:32:37 »
+1 for blue yeti
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
« Reply #6 on: Mon, 29 September 2014, 14:53:19 »
If background noise is a big problem, I would avoid condenser mics. They are quite sensitive, even if they have cardioid patterns. Perhaps you can find a way to apply a noise gate to your mic input?
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline Fragil1ty
  • Abre los ojos.
« Reply #7 on: Wed, 01 October 2014, 21:09:36 »
Are there any programs out there that may do this? I'd love to know, it would save me going and buying a new microphone for essentially nothing.
你搞砸了
