Author Topic: Poker 2 Backlit Keycaps  (Read 2989 times)
Offline Demetrium
« on: Mon, 29 September 2014, 11:18:50 »
I recently got a back-lit Poker 2 through MassDrop and quickly realized it didn't come with back-lit keys.
MassDrop also has a drop for some Vortex back-lit keys ending real soon. I was thinking of joining the drop, but before I did was wondering if anyone had a better recommendation? I was hoping to find Poker 2 specific caps (with the fn layer text on the keys) but some quick Google searches came up with nothing.
Thanks in advance for any suggestions!
Offline MrexD
  • aka mrwoodyxd
Pok3r MX CLears
Offline Demetrium
Re: Poker 2 Backlit Keycaps
« Reply #2 on: Mon, 29 September 2014, 11:44:49 »
Yup
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/pbt-key-caps-87-104-108-oem-se/poker-2-replacement-caps-led-c/lid=42017466
Let us know what they're like.
Thanks! Interesting...they look a lot like the stock keys from my CM Trigger. The paint on those came off within a year which makes me a little apprehensive.
Offline Lastpilot
  • Power stance
« Reply #3 on: Mon, 29 September 2014, 12:11:41 »
Don't forget the Ducky shine keycaps will also work from keyboardwow.com :]
Offline Demetrium
« Reply #4 on: Mon, 29 September 2014, 13:30:15 »
Thanks! I also had another question about back-lit keycaps while we're on the topic.
I got some LED color changers the other day to use on my Poker 2. I stole a few keys from my CM Trigger and notice that my purple changers are showing up as more of a pink. Any thoughts on if this is due to the color changer, LED, or the keycap? The LED is white, and the keycap itself is made out of more of a white plastic rather than clear. Wasn't really sure what was influencing it the most (this is my first time messing around with white LEDs and color changers).
« Reply #5 on: Mon, 29 September 2014, 13:33:14 »
imsto white PBT also let a lot of light through. They are the ideal backlit Keycap IMO.
I can post a pic of my backlight modded poker 2 with imsto keycaps if you like.
« Last Edit: Mon, 29 September 2014, 13:34:51 by dorkvader »
Offline Demetrium
« Reply #6 on: Mon, 29 September 2014, 13:49:30 »
Awesome, please do!
« Reply #7 on: Mon, 29 September 2014, 13:54:58 »
Awesome, please do!
my usb cable is only like 4" so I was limited with my background
BRB hitting up monoprice for more.
Offline Demetrium
« Reply #8 on: Mon, 29 September 2014, 14:06:48 »
Awesome, please do!
Looks awesome! Thanks!
