Author Topic: Looking for keyboards with non-M-style matrices  (Read 4847 times)
Offline huha
« on: Mon, 22 June 2009, 12:14:18 »
Hi there,
is anyone with keyboards with non-M-style matrices willing to open them up and take some pictures?
If you supply the pictures, I'll do a matrix trace. I'm only interested in keyboards without an M-Style matrix and without NKRO; I already did a trace on an m-style board and nkro matrices are boring and uninteresting.
So, what do I need?
- Highres pictures of the actual PCB where all traces are clearly visible. If you can't fit it on one picture, make several overlapping pictures so they can be stitched together.
- A picture of the front of the board so I get to know where all the keys are located.
- If it's a membrane matrix, pictures of both layers would be really great, which makes tracing much easier.
If you have what I need, write me and I'll give you my e-mail address or upload it somewhere and give me the link. It's important the image quality is as good as possible, so no unneccesary compression to keep down the file size should be employed. It's best to take the pictures straight from the camera.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline ch_123
« Reply #1 on: Mon, 22 June 2009, 12:40:49 »
Do Dell ATs have IBM matrices?
Offline huha
« Reply #2 on: Mon, 22 June 2009, 13:11:21 »
Quote from: ch_123;98327
What can you press simultaneously when trying QWAS?
If you can supply me with pictures, though, I'd be happy nonetheless. Pictures of board PCBs are fine even if they don't happen to have interesting matrices.
-huha
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #3 on: Sat, 27 June 2009, 19:20:38 »
1996 vintage 102-key G80-3000 with old-style Cherry matrix:
Back side of board, upside down [4.8 MiB - pic straight out of camera]
Yep, that's quite some flux on there. Have some more pics if required.
Top view:
« Last Edit: Sat, 27 June 2009, 19:26:04 by keyb_gr »
Offline huha
« Reply #4 on: Sat, 27 June 2009, 20:00:58 »
Looks interesting!
The PCB picture's quality is just slightly lacking, making it quite hard to effectively figure out where everything is connected to. I'll have to make more assumptions than neccesary. Do you have slightly larger pictures?
-huha
Offline huha
« Reply #5 on: Tue, 28 July 2009, 14:18:35 »
Still looking for PCB shots of various keyboards, by the way.
-huha
Offline lowpoly
« Reply #6 on: Wed, 29 July 2009, 10:53:14 »
I asked this in another thread, not sure if you've seen it: Why do you do this?
Offline Rajagra
« Reply #7 on: Wed, 29 July 2009, 14:45:23 »
I'd just like to chip in and say I'm disappointed with the M-style matrix. On my Unicomp Customizer you can't for example hold down both Control keys and get either Shift key to register. This has implications for anyone using Autohotkey wanting to turn a key into a Fn modifier (like Ripster's HHKB emulator or my Squeezeboard script.)
Maybe this is a criticism of all keyboards without N-key rollover, but until now I assumed the modifier keys were guaranteed to work. Silly me.
Offline keyb_gr
  • Cherrified user
« Reply #8 on: Wed, 29 July 2009, 14:53:01 »
LCtrl + RCtrl + LShift does work for me, but with RShift it doesn't (1931403). Guess I'd never have noticed.
Offline Rajagra
« Reply #9 on: Wed, 29 July 2009, 15:06:37 »
Ah - the Windows and menu keys on mine are probably hogging valuable positions.
I guess when compromises are being made, the ability to use both Control keys (or both Shift keys) is not a high priority.
Offline keyb_gr
  • Cherrified user
« Reply #10 on: Sun, 02 August 2009, 13:20:56 »
Here's a 1993 G80-3000HAD / 10 PCB in 3 shots. As it doesn't make any use of the integrated wire bridges for the most part, tracing shouldn't be too hard I hope.
Offline vils
« Reply #11 on: Sun, 02 August 2009, 15:07:03 »
I'll submit a pic of my SMK-85 as soon as I can.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline vils
« Reply #12 on: Thu, 06 August 2009, 13:49:21 »
SMK-85
First time I used this camera, didn't get the white balance right nor the focus...
Offline keyb_gr
  • Cherrified user
« Reply #13 on: Thu, 06 August 2009, 15:20:37 »
Indeed, that's a remarkably bad picture for a DSLR. ;) Actually it doesn't even show the matrix...
Offline vils
« Reply #14 on: Thu, 06 August 2009, 15:37:53 »
I'll educate me on the camera tomorrow ;)
Offline keyb_gr
  • Cherrified user
« Reply #15 on: Thu, 06 August 2009, 15:46:08 »
They have a "The Windows logo is a registered trademark of Microsoft Corporation" sticker UNDERNEATH THE PCB?
:jaw:
Offline vils
« Reply #16 on: Thu, 06 August 2009, 15:48:39 »
Good place in my opinion, I wish they could place that little domed flag underneath the keycap to.
Offline Rajagra
« Reply #17 on: Sun, 13 September 2009, 05:05:33 »
Not sure if you're still interested, but here's the DASIII.
http://www.g-ray.co.uk/pictures/DAS3mainboard.JPG
P.S. It has diodes on the other side. Can't photograph, the switch mounting plate hides that side.
« Last Edit: Sun, 13 September 2009, 05:11:18 by Rajagra »
