Author Topic: MX Green Springs = ?  (Read 1719 times)
Offline awhitedev
« on: Tue, 30 September 2014, 10:32:38 »
I have some extra green switches laying around and was wondering if the springs in them were the same stiffness as those found in the black switches.
I was thinking about putting green springs in some clear switches to make them more smooth.... but don't really want to make the clear switches any more stiff than they already are.
Thoughts?
Offline azhdar
  • Praise the AZERTY god
Re: MX Green Springs = ?
« Reply #1 on: Tue, 30 September 2014, 10:35:14 »
Green are 80g while black are 60g according to deskthority
Azerty Propagandiste
Offline Laser
« Reply #2 on: Tue, 30 September 2014, 10:37:21 »
Different measurements: AFAIK green springs = black springs (80g), that's why people make ghetto greens from blue stems + black springs.
Clears with black springs (panda clears) are popular, same with 62/65/68g custom springs (ergo clears). Just don't go lower or your spring may not push your stem back.
« Last Edit: Tue, 30 September 2014, 10:39:02 by Laser »
Offline awhitedev
« Reply #3 on: Tue, 30 September 2014, 10:42:48 »
According to this page... http://imgur.com/a/RJqM4.. they look very similar.
I guess I was hoping the extra 20g of force comes from the green stem being different than a linear one. If I put the same spring in a clear I would think the force would be more but by how much I'm not sure.
I like the idea of making some panda clears... I do enjoy slightly heavier switches. Do you think the green spring in a clear housing would be similar to a panda clear with black springs? Sounds like it should be...
Offline Laser
« Reply #4 on: Tue, 30 September 2014, 10:47:16 »
Yep, it should be.
Many people (myself excluded) like clears as they are: their default springs teach you not to bottom out, because if you don't, they are not tiring.
