Author Topic: Poker x fitting on a poker 2 case?  (Read 3782 times)
Offline concept73
« on: Wed, 01 October 2014, 12:46:55 »
Evening all, just wondering if i can fit a poker x onto a poker 2 case, got a lovely alu poker 2 case but thinking about buying a poker x and wondering if it fits.
Thanks in advance :)
Poker 2 with reds
Soon to be a JD40 with reds
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
Re: Poker x fitting on a poker 2 case?
« Reply #1 on: Wed, 01 October 2014, 13:15:48 »
They have the same mounting points so yes!
Offline epzy
  • HHKB Fiend
  • ded
« Reply #2 on: Wed, 01 October 2014, 13:17:34 »
Yeah it does.
Offline heedpantsnow
  • Old enough to know better
« Reply #3 on: Wed, 01 October 2014, 13:23:02 »
No prob
I'm back.
Offline concept73
« Reply #4 on: Wed, 01 October 2014, 13:35:34 »
Awesome, thank you guys, always nice to have that little confirmation makes me sleep better at night ;)
Poker 2 with reds
« Reply #5 on: Wed, 01 October 2014, 13:40:40 »
I thought the poker 2 has additional mounting points that the poker X does not (like the one in the center). As long as there are no components blocking that mounting point and you are okay with having a screw left over then it should otherwise work.
Offline Signature
  • master of puppers
  • snoozing
« Reply #6 on: Wed, 01 October 2014, 13:44:22 »
Thatīs true! Didnīt thought of that, Thank you!
« Reply #7 on: Wed, 01 October 2014, 13:50:02 »
looks like there is a diode in the middle. The standoff might fit. You can always do this mod and it will fit for sure though:
http://wiki.geekhack.org/index.php?title=Modifications:KBC_Poker_X:Pure_Center_Support_Modification
Offline frosty
  • jukebox hero
« Reply #8 on: Wed, 01 October 2014, 20:46:20 »
Wait a minute... where can you still buy poker X's now?
Offline FrostyToast
  • Litshoard
« Reply #9 on: Wed, 01 October 2014, 21:04:58 »
Classifieds
Quote from: elton5354
Offline frosty
  • jukebox hero
« Reply #10 on: Wed, 01 October 2014, 22:10:55 »
Classifieds
oh... got my hopes up...
Offline Oobly
« Reply #11 on: Thu, 02 October 2014, 00:52:32 »
I recommend you do the mod dorkvader posted. It will increase the stability of the board nicely. It's a nice board, I particularly like the togglable arrow key cluster. I have actually found that a PCB mount board in an aluminium case feels a lot like a plate mounted board due to the stiff support it gets from the case (I have a Pure Limited). So no real need to add a plate unless you're obsessive like me  ;)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline concept73
« Reply #12 on: Thu, 02 October 2014, 03:38:20 »
Ah sweet, yeah buying it off a friend of mine, its got mx blues on the base and mx clears on the mods :P
Poker 2 with reds
Offline frosty
  • jukebox hero
« Reply #13 on: Thu, 02 October 2014, 04:27:06 »
Does he have extras :P
Offline concept73
« Reply #14 on: Thu, 02 October 2014, 12:05:59 »
I actually sold it to him in the first place haha but he has just got a filco, and im only buying from him for him to fund the filco! but i might sell it on as i already have my poker 2 fully modded and got a JD40 on the way :)
Poker 2 with reds
Offline frosty
  • jukebox hero
« Reply #15 on: Thu, 02 October 2014, 12:29:33 »
can i has the dibs
Offline concept73
« Reply #16 on: Thu, 02 October 2014, 12:36:08 »
If i decide to sell you'll be the first in line :)
can i has the dibs
If i decide to sell you get first dips, and it also has an acrylic case :P
Poker 2 with reds
