Author Topic: Acrylic ErgoDox Case  (Read 2325 times)
Offline ron953
  • I sort of like typing.
« on: Thu, 02 October 2014, 11:35:09 »
I have access to a water jet cutter at my university and wanted to know where I could find the files for a layered acrylic ErgoDox case similar to the one they sell at mechanicalkeyboards.com with PCB mount stabilizer support. Would I have to design it myself? I would also probably be able to make more than one if anyone else is interested. Thanks for any help or input.
Offline AKmalamute
  • HHKB Scrub
Re: Acrylic ErgoDox Case
« Reply #1 on: Thu, 02 October 2014, 12:14:36 »
Classic or Full-hand?
I think I got my copy from GitHub, but also possibly just attached to the 'ergodox' thread that's stickied and has about a thousand posts to dredge through.
I'm running a GB for cases in metal, using the same files ... I see if I can't get them to you.
HHKB-lite2, Dvorak user
Offline vvp
« Reply #2 on: Thu, 02 October 2014, 12:35:31 »
Offline AKmalamute
  • HHKB Scrub
« Reply #3 on: Thu, 02 October 2014, 12:37:57 »
http://ergodox.org/Downloads.aspx
Sorry, no. They're missing. Have been for quite a while now.
Here, I had somebody downgrade the .dxf to be Autocad-2000 compatible. Those are the classic files but I've got full hand too.
« Last Edit: Thu, 02 October 2014, 12:44:08 by AKmalamute »
Offline ron953
« Reply #4 on: Thu, 02 October 2014, 13:04:54 »
Thanks for the link AKmalamute! With the mk.com version with the aluminum top plate, is the top layer the same but in metal? Thanks.
EDIT: Also, do you recommend classic or full-hand? Are there drawbacks to either one?
« Last Edit: Thu, 02 October 2014, 13:06:34 by ron953 »
Offline vvp
« Reply #5 on: Thu, 02 October 2014, 17:33:14 »
Right, it does not work any more.
There were times when it worked. I downloaded it from there.
