Author Topic: CM QuickFire Rapid-i OEM and key stabilizer quality  (Read 11843 times)
Offline kaliuseruser
« on: Fri, 03 October 2014, 09:37:52 »
1) My first question is about the manufacturer of Rapid-i, is it made by Costar or did they change the OEM ? china or taiwan ?
2) My second question is about the key stabilizer, it appears that the they changed the stabilizer from Costar to Cherry stabilizer, is this an indication that this new product will be of a less quality then the original ?
3) I know that Cherry stabilizer can different from one keyboard to another, so how does the Rapid-i Cherry stabilizer compare to other say like ducky 3 Cherry stabilizer ?
4) Some people report that Cherry stabilizer feel mushy to type on, what does the word "mushy" mean here, is it like easy to type on or what exactly ?
« Last Edit: Fri, 03 October 2014, 09:45:09 by kaliuseruser »
Offline duzeyao
Re: CM QuickFire Rapid-i OEM and key stabilizer quality
« Reply #1 on: Fri, 03 October 2014, 11:03:20 »
1/ It's made in China mainland
2/ It's of cherry stabilizers but the typing feel of long keys is kind of loose, compared to Cherry keyboards.
3/ Costar - Rapid-I - Cherry - Ducky imo, from loose to mushy.
4/ Well I think you won't be disappointed by the cherry stabilizers of Rapid-i.  :p
你绝版的婊子妈坟
« Reply #2 on: Fri, 03 October 2014, 11:06:27 »
Mushy meaning it feels like there is extra resistance when you push down on the key. Typically when you press down on the key, you just feel the switch actuation. Some modifiers feel like there is extra resistance so the alphas don't feel the same as the modifiers. It's almost like your cap has some syrup in it and it's pushing back more than it should.
« Reply #3 on: Fri, 03 October 2014, 11:25:44 »
did they change their OEM or are they still manufactured by Costar ?
« Reply #4 on: Fri, 03 October 2014, 11:32:33 »
I think the only reason why QFR-i used Cherry stabilizer is because of backlit, which gives the impression that corsair stabilizer are indeed better for typing, this is just a speculation from my part, I'm by no means an expert in mechanical keyboards.
what do you think, does Costar stabilizer feel better to type on ?
Originally I settled to get a Das keyboard but after they changed their manufacturer I started looking for an alternative, now I'm trying to decide between QFR and QFR-i which one do you think is better for typing.
« Last Edit: Fri, 03 October 2014, 11:41:20 by kaliuseruser »
« Reply #5 on: Fri, 03 October 2014, 11:38:09 »
Well not every Cherry stabilizer feels the same and if you clip them, they're great. I prefer clipped Cherry stabilizers. As always, "better" is subjective and you'll have to decide for yourself.
QFR vs QFR-I? I wouldn't know because I've never tried a QFR-I for myself. And I haven't seen much information about the QFR-I. I will say that I like the QFR as long as I don't need to modify anything and keep it stock. It's not my favorite board to mod. The QFR-I looks nice though. If you're looking for a solid board, I'd look into getting a Ducky or Leopold. I own a Leopold and I've had Ducky boards in my possession for a long period of time. Really enjoyed those boards.
 I've also liked what I've seen from the KUL and WASD boards.
« Reply #6 on: Fri, 03 October 2014, 12:00:57 »
I don't plan to mod the keyboard, and from this typing video (http://www.youtube.com/watch?v=zQ5eTQ6nhF4) the spacebar seems to work great, what do you think ?
The last thing I want to know is obviously the OEM, is it still Costar ?
« Reply #7 on: Fri, 03 October 2014, 12:03:53 »
what do you think ?
I don't know. The Costar OEM is always confusing to me because they're essentially a middle man so I think there's varying Costar qualities. I could be wrong but that's what I remember...Regardless, I think it's a solid board.
Offline phoenix1234
« Reply #8 on: Fri, 03 October 2014, 12:35:01 »
Yes, it's 100% Costa. You can see the keyboard code : CST-87-TENKEYLESS and it is exactly what on Costar side :
http://www.costar.com.tw/index.php?option=com_flexicontent&view=items&cid=52%3Amechanical-keyboard-or-keyboard-moduleoemodm-&id=69%3Acst-87-tenkeyless&Itemid=87&lang=en
I like linear switches
Offline wes1099
  • Technology and Dog Enthusiast
« Reply #9 on: Fri, 03 October 2014, 14:16:58 »
A little off topic, but does anyone know if the QFR-i has a replacable controller like the QFR? I like the cool backlighting stuff on the QFR-i but I don't want to get it if I can't make it fully programmable.
[Leopold FC660C]     [GON NeRD 60]    [Infinity Keyboard]    [ Model M Silver Label]
[Topre 45g Silent]     [Gateron Black]    [Cherry MX Black]     [Model Number 1390636]
        [May 20, 1987]
« Reply #10 on: Fri, 03 October 2014, 14:38:29 »
i don't think it has one yet
Offline wes1099
« Reply #11 on: Fri, 03 October 2014, 14:41:58 »
Oh I know that. I just don't know if it even has a removable controller.
        [May 20, 1987]
« Reply #12 on: Fri, 03 October 2014, 14:45:14 »
technically speaking yes you can take it off
I don't think it's like an old school QFR one tho
might be a microcontroller because LEDs
Offline wes1099
« Reply #13 on: Fri, 03 October 2014, 14:50:12 »
Yeah, I was thinking that it was probably a tiny SMD chip like the one on my Quickfire TK, but I wasn't sure.
        [May 20, 1987]
« Reply #14 on: Fri, 03 October 2014, 15:34:34 »
where did you see the keyboard code CST-87-TENKEYLESS ? did you open a QFR-i and found that code inside it ?
Offline phoenix1234
« Reply #15 on: Fri, 03 October 2014, 17:17:56 »
No, I didn't open it inside to seek for it. But the question was answered on this thread and on Amazon Q&A
http://geekhack.org/index.php?topic=60411.10
http://www.amazon.com/Cooler-Master-Tenkeyless-Mechanical-Individual/forum/-/-/1?_encoding=UTF8&asin=B00JM61264
I think we can trust Q&A from CM rep at Amazon.
« Reply #16 on: Fri, 03 October 2014, 19:34:57 »
I think any person can put an answer in Q&A at amazon, what makes you think that the person that answered that question is a CM rep ?
Anyway, it would be cool if you could tell me how does the stablizers feel on your QFR-i.
Offline phoenix1234
« Reply #17 on: Fri, 03 October 2014, 20:16:17 »
Oh, I thought he is one of CM rep. He sounds quite certainly. You're right, we should just ignore that factor.
Anyway, if we can consider all Chinese manufacturers who produce led TKL and standard R1, likely it will lead to Vortex, Ducky Zero, Plum and perhaps Costar etc.
So we can at least assume Quick Fire Rapid-I is CST-87-TENKEYLESS until someone prove otherwise because the looks and the keycap OEM similar to Rapid and according to this http://deskthority.net/wiki/Costar
"Costar is alleged to not be a manufacturer; rather, they have been described as a middle-man between their customers and their manufacturers.[1]"
Regarding the stabilizers feel, I feel it is similar like Ducky Shine 3 because they are both Cherry Plate mounted stabilizers. Comparing between Ducky Shine 3 TKL and Rapid-I, I would prefer Ducky Shine 3 TKL because of it build quality to be honest, it's rock and solid but indeed, the price of Ducky Shine 3 TKL is more expensive.
« Last Edit: Fri, 03 October 2014, 20:24:49 by phoenix1234 »
Offline duzeyao
« Reply #18 on: Sat, 04 October 2014, 00:26:54 »
Yep they changed the OEM to a mainland factory (I think it's the same as Ultimate and TK), NOT Costar.
你绝版的婊子妈坟
Offline phoenix1234
« Reply #19 on: Sat, 04 October 2014, 08:23:38 »
Do you have any evidence to back that up?
I doubt that because the last row of Ultimate and TK are abnormal while the Rapid-I is standard like Filco and Ducky (1.25 _ 1.25 _ 1.25 _ 6.25 _ 1.25 _ 1.25 _ 1.25 _ 1.25 _ 1_1_1).
The PCB is quite clean and neat:
The Controller is ARM Holtek like Ducky:
The Plate is quite nice and clean:
Overall the keyboard is similar to Costa
Source: http://www.modders-inc.com/cm-storm-quickfire-rapid-keyboard-review/
However, we have no confirmation from CM who is their OEM so it could be anyone. It could even be the Vortex or a disclosed OEM.
Offline duzeyao
« Reply #20 on: Sun, 05 October 2014, 01:35:54 »
Yes I am 100% sure QFR-I is not manufactured by Costar (I had some communications with CM keyboard designer).
I'm not very sure however if it's produced by the same factory as TK though.
Anyway the build quality of QFR-I is good.  :))
你绝版的婊子妈坟
