Author Topic: Solidtek 6600-ABU value for money  (Read 4818 times)
Offline iggysaps
« on: Wed, 24 June 2009, 04:44:07 »
Well if you are into brand new mechanical keyboards and are just starting your collection, I guess this solidtek with fake white alps will be worth it.  It costs about US$48 around $53 with shipping within the US.  It's comparable to the feel of the DELL AT101W which has black alps just a bit softer snap back on the keys.
It is clicky and tactile and a good start for a mechanical keyboard newbie.
Don't know if anyone else wishes to comment, since I barely hear it mentioned on the boards..:smile:
Cherry G84-4100 cherry ML switches
Cherry G80-3000 blue cherries
Dell AT101W (2)
Solidtek ASK-6600
Unicomp Spacesaver buckling spring
Key tronic designer P2
Offline huha
« Reply #1 on: Wed, 24 June 2009, 12:21:29 »
Quote from: iggysaps;98735
Do you wish to take some pictures and upload some sound samples?
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline maxlugar
« Reply #2 on: Thu, 06 August 2009, 18:15:34 »
This is a decent keyboard for the money.  I actually prefer this keyboard over the $189 CVT Avant Stellar.  With its metal case, the Avant Stellar is much heavier.  But the Avant typing action is kind of sloppy. Also, the Avant Stellar key caps are labeled with stick-on decals.
The fake ALPS used in the DSI/Solitek 6600 are not like the real (complicated) ALPS keyswitches used in the Northgate Omnikeys. But by the same token, the brand new Solitek 6600 is 1/4 the price of a used Northgate Omnikey 102 and is better made than 95% of keyboards currently manufactured in China.
I do not agree that the key action is similar to the Dell AT101W.  The Dell uses linear "non-clicky" ALPS keyswitches.  The key switches used in the Solitek 6600 have a definite tactile bump and audible click.
Emperor of the IBM 84-key AT Model F Darkside
Offline timw4mail
    • https://timshomepage.net
« Reply #3 on: Thu, 06 August 2009, 19:20:32 »
Quote from: maxlugar;107692
You know, the Dell actually isn't linear, but it is pretty close. It has the most subtle tactile point out of any keyboard I've tried.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline maxlugar
« Reply #4 on: Thu, 06 August 2009, 22:15:20 »
Quote from: timw4mail;107719
I haven't noticed the bump.  It must be very subtle, but since my daily driver is an IBM 84-key PC AT keyboard, all other keyboards seem linear to me. :heh:
Admittedly, I haven't done much typing on my Dell AT101W so I'll have to check it out again to see if I can discern the subtle tactile point.
Offline patrickgeekhack
« Reply #5 on: Fri, 07 August 2009, 00:03:01 »
Quote from: huha;98846
Yes OP. It would be nice if you could post some pictures and a sound sample. Like you said, it does not get talked about a lot.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline iggysaps
« Reply #6 on: Fri, 07 August 2009, 00:45:37 »
Am a bit busy these days.  But if I find time, I will post some pictures, and a sound sample.  I don't use it much.  But it is better than nearly all the rubber domes.  A bit noisy though.
Dell AT101W (2)
Solidtek ASK-6600
Offline itlnstln
« Reply #7 on: Fri, 07 August 2009, 08:52:56 »
As you move from heavier key switches to lighter ones, tactility is hard to detect until you lighten your stroke.  I, personally, find the Dells very tactile, but I had been using Alps for quite some time when I first tried it.  When I tried Cherry browns after using the Alps, I thought they were overrated and pretty much linear.  After I used my MX-11800 for about a week, or so, and further lightened my touch, I could easily feel the tactile bump.
Offline cmr
« Reply #8 on: Fri, 07 August 2009, 10:27:28 »
yeah the at101w i am on right now has a definite tactile click but basically no audible click
Offline Special K
« Reply #9 on: Sat, 08 August 2009, 11:42:54 »
The keys also seem to take longer to bounce back up after you release them, but maybe that's just my imagination.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
« Reply #10 on: Sun, 09 August 2009, 12:13:17 »
Quote from: Special K;108199
Unfortunately, we don't have any objective way of measuring this. Could it because Alps switches require a little bit more force than say blues cherries? More force = more time before moving to other keys? Just a thought.
Offline itlnstln
« Reply #11 on: Mon, 10 August 2009, 08:39:33 »
I am no professor of physics, so I can't explain it, but Cherry and BS springs seem to have more "spring" in them than those used in Alps (and clones) switches.  Even my browns that have lighter springs than Alps seem to bounce back stronger than any of the Alps keyboards that I have used.  After using Cherry switches, Alps feel more clunky and slow in comparison.  Even the heavy BS feel more nimble than Alps, IMO.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #12 on: Mon, 10 August 2009, 09:24:49 »
Quote from: itlnstln;108576
That's easily explained when looking at force graphs. Clicky Alps seem to hold an approximately constant force after activated, while BS and Cherry switches show a linear increase again.
Offline itlnstln
« Reply #13 on: Mon, 10 August 2009, 09:26:55 »
Quote from: keyb_gr;108591
Right, but what I can't explain is why.  Is it in the desighn of the springs, or is it in the overall switch design?
Offline cmr
« Reply #14 on: Mon, 10 August 2009, 09:49:59 »
is this keyboard available without the weird enter key?
