Author Topic: Any 60% case like KMAC Happy's case?  (Read 3696 times)
Offline Karura
  • Professional Canadian
  • SKidata life.
« on: Sun, 05 October 2014, 04:56:18 »
Hello,
I really like the KMAC Happy's case, not this one specifically, but one that is full 60% layout with ctrl keys:
My only problem with KMAC Happy is that I'm looking for a silver or unanodized plate with notches for quick switch removal.
That said, my two options are:
1. Find a case similar to KMAC Happy's case and use universal 60% plates/PCBs.
2. Find a new plate with notches for the KMAC Happy.
I've done some looking around, and seems like both options aren't possible.
Do you guys know of any cases that are similar the KMAC Happy in the incline angle (similar to a normal keyboard without feet-propped up), and very blocky/sharp, as opposed to most of the poker/60% cases I see that are too round or "floating". Kinda really like the colour and finish of it. I also like the Hammer case for pokers, but it's incline is a bit steep.
Offline feizor
Re: Any 60% case like KMAC Happy's case?
« Reply #1 on: Sun, 05 October 2014, 05:38:26 »
Duck viper, steep incline though, something like 11 degrees.
Offline Karura
  • SKidata life.
« Reply #2 on: Sun, 05 October 2014, 05:47:06 »
Right, the Viper is another option, but not exactly what I'm looking for because it's a little inclined like you mentioned, also hard to get!
I'm looking for something.. maybe like Hammer case, where I can pick whatever PCB I want, whatever plate, then build my own keyboard
It just feels like almost all current in-stock options are too round, TEX's cases are round on the corners, same with some other cases. Nothing really "sharp" like the KMAC Happy =/
Offline Karura
  • SKidata life.
« Reply #3 on: Sun, 05 October 2014, 07:05:13 »
Looks like I might be considering the FMJ case :)
