Author Topic: What caps would fit...?  (Read 3870 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Sun, 05 October 2014, 21:32:51 »
This das is weird compared to what I see online.....
4 keys on either side of space bar vs what I've seen 3 on left 4 on right...
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: What caps would fit...?
« Reply #1 on: Sun, 05 October 2014, 21:48:20 »
The bottom row appears to be
1.25 - 1 - 1 - 1.25 - 6 - 1.25 - 1 - 1 - 1.25
Good luck with that one.  Six unit space bars are pretty odd and tough to find especially in a group buy.  The rest of it is standard ANSI with the exception of the other mods but those would usually be covered in the group buy.
Offline C5Allroad
« Reply #2 on: Sun, 05 October 2014, 21:49:33 »
Gonna be fun to find a set... I don't like these printed caps. And the white is grey now lol
Offline Coreda
« Reply #3 on: Sun, 05 October 2014, 22:42:24 »
You simply won't believe what board's caps are puzzling this well-known poster... couldn't resist ;p
Offline Oobly
« Reply #4 on: Mon, 06 October 2014, 01:47:49 »
~Really? Fun?
I would think it'd be a PITA to find a set to match.. 6x spacebar will be the hardest, there are quite a few sets with extra kits that you can fill up the bottom row with as long as you can find a matching 6x spacebar.
The Razer Blackwidow uses 6x, but I doubt you'd want to use the caps from that. Also some Cherry boards have 6x spacebars (1800, 11800, etc), but the stem spacing may not match. Good luck.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Oobly
« Reply #5 on: Mon, 06 October 2014, 04:00:28 »
Offline C5Allroad
« Reply #6 on: Mon, 06 October 2014, 10:21:26 »
Eh, I don't really want the semi translucent stuff... Prefer black with white legends.
Offline Oobly
« Reply #7 on: Mon, 06 October 2014, 15:04:13 »
If you pull the spacebar off and show us the underside we can see if the Cherry G80-11800 style spacebar would fit. You could then mix and match some Cherry profile sets to get a full set. If not, you've got a hard search ahead of you unless you don't mind a mismatched spacebar (keep the original on and replace all the other caps only).
Offline C5Allroad
« Reply #8 on: Mon, 06 October 2014, 17:12:27 »
I'm not home now, but I know that it has more than 3 stems. Will update later :)
Offline C5Allroad
« Reply #9 on: Mon, 06 October 2014, 19:17:46 »
This board is really weird to me lol...
But I do enjoy blues.
« Last Edit: Wed, 08 October 2014, 18:16:37 by HUNTERANGEL121 »
Offline a Horde of Penguins
« Reply #10 on: Fri, 10 October 2014, 20:32:52 »
i have the same board only with blanks, hope my new keycap set fits if not i wasted 26 dollars on shipping
http://www.ebay.com/itm/PBT-Keycap-Set-for-Cherry-MX-based-Leopold-Keyboards-Front-Face-Englih-Black-/281377716241
edit; mine is slightly different i dont have any 1's on the bottom row
Offline Oobly
« Reply #11 on: Sun, 12 October 2014, 04:12:45 »
Yup, looks like it'll fit nicely!
