Author Topic: Japanese spacebar for MX?  (Read 2307 times)
Offline Hubbert
« on: Mon, 06 October 2014, 02:04:05 »
Is there any mainstream source in the US for a Japanese MX spacebar?  I could use shift keys, but a spacebar should be convex.
FYI, US left space is 2.25 U, right space is 2.75 U, and spacebars vary around the ~6-7 U.  I think Japanese spacebars are around 2.5 U.
« Last Edit: Mon, 06 October 2014, 02:21:07 by Hubbert »
Current: ThinkPad, Modified Model M, Customozed Unicomp on order.
Occasional: Acer (rubber with sharp edged keycaps)
Storage: Kinesis Advantage (Cherry brown), PC Concepts split keyboard (ALPS white)
Scorpius M10 (Cherry blue)
Re: Japanese spacebar for MX?
« Reply #1 on: Mon, 06 October 2014, 16:51:59 »
check SP's stock list, they might have something is DSA for you
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Thu, 09 October 2014, 09:15:36 »
Most JIS boards do use a shift key for space, unless it's a larger 4.x key like on Filco MJ or Ducky they don't tend to have the convex spacebar shape on under 3u. If the edge bothers you using a shift key just put it on upside down, problem solved.
Offline Hubbert
« Reply #3 on: Sat, 11 October 2014, 18:01:00 »
Thanks for the info: it's surprising that such an advanced country lacks proper spacebars.  Another alternative is to just cut down a normal spacebar.
« Reply #4 on: Mon, 13 October 2014, 08:46:41 »
Space isn't used the same way in Japanese, so it isn't really as important as other languages. I guess they just don't really care about it much and they needed to put all those IME keys in there.
