Author Topic: Das keyboard possible customization  (Read 2543 times)
Offline a Horde of Penguins
« on: Wed, 08 October 2014, 00:26:30 »
I am thinking of going over my finger print black hole (my das s ultimate) with a vinyl wrap, this one in particular
http://www.amazon.com/3M-MATTE-White-Scotchprint-Series/dp/B00598SB40/ref=sr_1_12?s=automotive&ie=UTF8&qid=1412745556&sr=1-12&keywords=matte+vinyl+wrap
though if they make cyan wraps someone needs to tell me.
anyways i was wondering everyone's thoughts/tips about going about this.
(what is 3M, m10, and does it being labeled carbon matter (just looks like a texture to me))
Re: Das keyboard possible customization
« Reply #1 on: Wed, 08 October 2014, 15:41:42 »
no insite available then I'm assuming?
Offline MJ45
  • HHKB Pro
« Reply #2 on: Wed, 08 October 2014, 15:58:24 »
I do know 3M is Minnesota Mining and Manufacturing company (I used to work for them) they make very good products. As far as the m10 I'd guess it would be the products thickness. Get on 3M's website for the detailed product specifications and applications etc.
Offline trizkut
« Reply #3 on: Wed, 08 October 2014, 16:30:32 »
You might have an easier time plastidipping your case.  The color options might be better too (though I've never done it myself).
Found this album after a quick google:
http://imgur.com/a/s0Igs
« Reply #4 on: Wed, 08 October 2014, 17:09:41 »
that looks amazing will have to look further into that option, thankyou
