Author Topic: Nooo my C key's LED is dying :d  (Read 2247 times)
Offline Owntrolf
« on: Wed, 08 October 2014, 18:27:42 »
Goddammit my C key's LED is dying
Now im going need to fix tomorrow :(
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
Re: Nooo my C key's LED is dying :d
« Reply #1 on: Wed, 08 October 2014, 18:32:56 »
sucks now go buy a new kb
Offline Owntrolf
« Reply #2 on: Wed, 08 October 2014, 18:39:59 »
Nah I still have some the original green LEDs when I replaced some of the LEDs with white ones
Offline Oobly
« Reply #3 on: Thu, 09 October 2014, 00:49:18 »
Y, just swap it out. Although you should try to match the forward voltage drop to the others on the same resistor if they are grouped. Good to replace it ASAP in that case, too, since if one dies the others could get more current each. That said, most boards don't supply enough current to fry LED's easily, they're often running at a fraction of their max current rating. Better safe than sorry, though.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Owntrolf
« Reply #4 on: Thu, 09 October 2014, 01:52:18 »
My LEDs shouldnt die so easily since I usually type in reactive mode
Offline Oobly
« Reply #5 on: Thu, 09 October 2014, 03:44:24 »
If your board supports reactive mode, they probably all have their own resistor anyway, so no worries.
Offline paicrai
  • mindblank
« Reply #6 on: Thu, 09 October 2014, 03:48:16 »
THE FEMINIST ILLUMINATI
Offline Grim Fandango
« Reply #7 on: Thu, 09 October 2014, 05:12:29 »
That is one of the things I have about backlight leds (aside from the fact that I do not like the way it looks and it is distracting), they tend to die. There are so many brands where the leds are consistently the first thing to give out. LEDS on a keyboard simply means adding about 100+ extra things that are all more likely to break than anything else in the keyboard.
Offline AverageHybrid
« Reply #8 on: Thu, 09 October 2014, 05:54:10 »
nice wacom tablet though
Offline Owntrolf
« Reply #9 on: Thu, 09 October 2014, 10:50:41 »
Clearly uses tablet to play Osu
https://osu.ppy.sh/u/3689120
