Author Topic: Thumb Keys  (Read 4729 times)
Offline mozaiq
Thumb Keys
« on: Thu, 09 October 2014, 17:32:12 »
Hi,
I just had the opportunity to try Roccat Ryos for two weeks. Not my board, especially not the blacks it has, but that's not what I wanted to talk about. I really liked one feature this board has: thumb keys. Unfortunately, the way they are implemented seems not that good to me. They are flat and imho very hard to press, much harder than I would like. But that makes wonder: are there any other mechs out there, that have "real" thumb keys, i.e. mechanical keys? I found some that are similar to the Roccat, but besides this the only thing I found was this: http://www.gamdias.com/en/p/hermesgkb2010/ Never heard of this brand before, and I really dislike the fact that it is full size, but it's the only board I managed to find. The only other alternative I know would be split board like Ergodox, but I would highly prefer a normal shape in TKL or smaller. Any suggestions on this?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Thumb Keys
« Reply #1 on: Thu, 09 October 2014, 17:43:37 »
Tex Yoda, but it's probably not easy to get a hold of
Not sure about the programability of the thumb keys as they are meant to be mouse buttons for the trackpoint really.
« Last Edit: Thu, 09 October 2014, 17:45:34 by IvanIvanovich »
Re: Thumb Keys
« Reply #2 on: Fri, 10 October 2014, 05:53:43 »
I think the mouse is separate from the keyboard's microcontroller, unfortunately.
Offline yasuo
  • spanengan puyeng newbie
Re: Thumb Keys
« Reply #3 on: Fri, 10 October 2014, 05:57:48 »
i think this is better ;D
lowpoly design thumb keys behind spacebar with microswitch :))
Logitech MK220 Colemak DH
Offline mozaiq
Re: Thumb Keys
« Reply #4 on: Sun, 12 October 2014, 08:52:24 »
Not the answers I had hoped for, but what I suspected. It seems that thumb keys are only used in gaming boards. I guess I'll stick to SpaceFN then. But thanks for your suggestions anyway.
Offline yasuo
Re: Thumb Keys
« Reply #5 on: Sun, 12 October 2014, 09:11:44 »
or like this :) not really game only, modiefer on thumb keys more effective
« Last Edit: Mon, 13 October 2014, 03:48:51 by yasuo »
Re: Thumb Keys
« Reply #6 on: Sun, 12 October 2014, 15:26:24 »
There are a few keyboards that have the Spacebar split into two parts, where one is an additional Backspace.
The Matias ErgoPro is one, but it is also split. There are vintage full-size keyboards from NMB where the additional Backspace is called "Erase-Eaze".
Then there are some keyboards from Japan that have some special keys for Japanese in front of the space bar, but I think that those are mostly rare vintage keyboards that may not work with a modern PC without a special adapter. One example is a FM Towns keyboard which is in TKL form factor.
Regular modern Japanese keyboards have a small Space bar and the Japanese modifiers on the left and right sides.
« Last Edit: Sun, 12 October 2014, 15:43:25 by Findecanor »
Offline mozaiq
Re: Thumb Keys
« Reply #7 on: Sun, 12 October 2014, 16:43:10 »
Hi,
thanks for your suggestions. I already gave a thought to those Japanese boards, or bottom row styles that reassemble them. The problem is though that I seem to have big hands. Well actually I don't think that they are that big, but I just can't press alt with my thumb comfortably. With JIS the spacebar becomes smaller, but I am not sure whether those modifiers are near to thumb or not.
Also a drawback is that it is pretty hard to grab a hold one. Or really expensive.
I will let this slip for now I guess. I just customized SpaceFN to my needs and realized how many possibilities this single key offers. Maybe that's even enough for my needs. Or I will build a custom keyboard :cool: Although according to the time you can spend doing this, my girlfriend would probably kill me :D
Offline jacobolus
Re: Thumb Keys
« Reply #8 on: Sun, 12 October 2014, 20:08:35 »
Too bad there aren’t really any keyboards along the lines of..
