Author Topic: Which Dell is this  (Read 8282 times)
Offline jkkhop
Which Dell is this
« on: Sat, 27 June 2009, 04:05:04 »
Can you tell it by the picture?
Offline lowpoly
Which Dell is this
« Reply #1 on: Sat, 27 June 2009, 04:18:47 »
There were rumours of a rubber dome version of the AT/Bigfoot but I think people were talking of this one. Don't listen to me though, never had one of those.
Offline ch_123
Which Dell is this
« Reply #2 on: Sat, 27 June 2009, 05:56:50 »
It's definitely a Quietkey (rubber domes), not an AT101/102
Offline jkkhop
Which Dell is this
« Reply #3 on: Sat, 27 June 2009, 08:20:17 »
ok, thanks!
Offline huha
Which Dell is this
« Reply #4 on: Sat, 27 June 2009, 11:55:40 »
The AT102 (don't know about the 101) has a small ridge over the F keys, so it's fairly easy to tell.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline ch_123
Which Dell is this
« Reply #5 on: Sat, 27 June 2009, 12:30:02 »
The letters also have a different font.
Offline low-fi
Which Dell is this
« Reply #6 on: Sun, 28 June 2009, 08:31:09 »
This is a quality rubber dome keyboard, though. My father has used this Dell 'board for about ten years and it still works fine. It has quite a nice feel.
« Last Edit: Sun, 28 June 2009, 08:33:10 by low-fi »
Offline sandy55
Which Dell is this
« Reply #7 on: Sun, 28 June 2009, 09:47:46 »
Quote from: lowpoly;99571
Hi lowpoly.
It's not a rumor. Actually, ribber dome versions of bigfoot board exist.
AT101R/102R/103R are the number of such boards. R indicates rubber dome boards.
Can't point a right page with exact pictures but this page explains there ARE such models.
see dimension column.  "depth" is telling these are not Dell quiet boards with SK numbers.
the titled keyboard in question is a rubber dome board by Silitek.
Offline huha
Which Dell is this
« Reply #8 on: Sun, 28 June 2009, 09:58:43 »
You seem to know something about Dell keyboards, so:
What's the difference between an AT102W and an AT102DW?
-huha
Offline sandy55
Which Dell is this
« Reply #9 on: Sun, 28 June 2009, 10:10:43 »
102W might be a UK layout board with Windows keys.
I vaguely suppose 102DW would be German layout with win keys...but now sure.
103 indicates Japanese layout board, btw.
Offline huha
Which Dell is this
« Reply #10 on: Sun, 28 June 2009, 10:14:15 »
Quote from: sandy55;99756
The 102DW is indeed a German Layout with windows keys. Is there any system to it? The 101/102/103 defines the number of keys, W seems to denote Windows keys (?) and the other character different languages--does anyone have a list of existing models?
-huha
Offline sandy55
Which Dell is this
« Reply #11 on: Sun, 28 June 2009, 11:14:06 »
Strictly speaking, 101/102/103 defines basic layout at least in Dell's clasification.
101/US standard established by IBM with model M, usually called as ANSI, maybe.
102/ISO European layout.
Somebody may correct two above.
103/Japanese standard layout with 106 keys defined by OADG. This layout  started with a 5576-A01 keyboard and it is usually called as A01 layout.
I think 103 is used only by Dell.
Offline lowpoly
Which Dell is this
« Reply #12 on: Mon, 29 June 2009, 08:20:35 »
Quote from: sandy55;99752
Hi lowpoly.
Thanks for clarifying, sandy.
IIRC the AT103 was also available from HP? Were there other brands?
Offline sandy55
Which Dell is this
« Reply #13 on: Mon, 29 June 2009, 11:52:44 »
Quote from: lowpoly;99883
Not sure if HP branded AT ( or PS/2) compatible bigfoot boards exist or not.
But there is an AX keyboard.
AX boards are not fully compatible with OADG standard but can be used on M$ Windows
with an appropriate keyboard driver as like as 5576-001/002 ( I myself have not yet confirmed.)
Offline lowpoly
Which Dell is this
« Reply #14 on: Mon, 29 June 2009, 14:07:55 »
That's the one. Didn't see it was AX. Thanks.
Offline huha
Which Dell is this
« Reply #15 on: Mon, 29 June 2009, 15:39:19 »
Quote from: sandy55;99931
M$
Please don't write M$, write MS or Microsoft. M$ is just so incredibly childish.
-huha
Offline DrunkenDonut
Which Dell is this
« Reply #16 on: Mon, 29 June 2009, 18:51:22 »
I like the key, but wish the logo wasn't there. A generic symbol would be better IMO. The key itself is great for shortcuts and macros.
*Hang on to your wallet!*
BTC E5X5R5BTC-5339R-0 (\'90), MS Natural Keyboard Pro (\'99), Sun Type 5c, 2x 1391401, DASK3ULT (\'08), ABS M1, Dell AT101W, M4-1
FKBN87M/EB (\'09), FKBN87ML/EB (\'09), FKBN87Z/EB (\'09), FKBN87MC/NPEC (\'09), G80-3000LQCDE-2 (\'11)
Offline ch_123
Which Dell is this
« Reply #17 on: Mon, 29 June 2009, 18:56:32 »
I like that Diamond that Sun uses on their keyboards (also used on the HHKB). However, the standard gets forced down manufacturer's throats by MS, so most are just going to stick to the Windows logo.
Offline timw4mail
    • https://timshomepage.net
Which Dell is this
« Reply #18 on: Mon, 29 June 2009, 19:02:14 »
Quote from: ripster;100053
The logo is the best part.
According to a friend of mine, the newer Windows logo looks like a certain Nazi symbol...
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline huha
Which Dell is this
« Reply #19 on: Mon, 29 June 2009, 19:06:49 »
Quote from: timw4mail;100054
Sorry ripster, timw4mail just used Godwin's law to outchild you. You gotta try harder next time!
-huha
Offline HKEPCLED
Which Dell is this
« Reply #20 on: Tue, 30 June 2009, 11:46:38 »
"Silitek" SK-1000REW for sure
Offline Mr.6502
Which Dell is this
« Reply #21 on: Tue, 30 June 2009, 13:19:20 »
Quote from: HKEPCLED;100196
Do Dell keyboards with SK-#### in general come from Silitek?
I ask because I just found a keyboard for a friend, a Dell SK-8000 that is fantastic for gaming depending on the button layout you use.  If the SK means Silitek I might be tracking down more from that company to try their stuff out.
"Engineers are really good at labeling and branding things ...  If we had named Kentucky Fried Chicken, it would have been Hot Dead Birds."
-Vint Cerf
Offline ch_123
Which Dell is this
« Reply #22 on: Tue, 30 June 2009, 13:59:41 »
Dell ATs were also made by silitek, at least according to the markings on the PCB.
Offline lowpoly
Which Dell is this
« Reply #23 on: Tue, 30 June 2009, 14:43:36 »
Quote from: ch_123;100230
Some were made by Alps Korea, IIRC.
Offline HKEPCLED
Which Dell is this
« Reply #24 on: Tue, 30 June 2009, 21:12:05 »
Quote from: Mr.6502;100223
Dell major keyboard OEM factory :
SK-####  from "Silitek"
RT-####  from "NMB"
KB-####  from "Chicony"
