Author Topic: Both control keys stopped working?  (Read 2193 times)
Offline mattz330
« on: Fri, 10 October 2014, 08:17:40 »
Hey, both of my control keys have stopped working, Filco Majestouch 2 US Brown switches... I have no idea why?
Any help would be appreciated. Thanks
  • Live long and prosper
Re: Both control keys stopped working?
« Reply #1 on: Fri, 10 October 2014, 08:30:38 »
You have lost all control...
http://geekhack.org/index.php?topic=34670.msg641440#msg641440
This program will let you see every registered keystroke. If the keyboard is the issue (bad switches or controller) this program won't register your Control keys.
Diagnostics Step 1: Run tests.
tp thread is tp thread
Offline mattz330
« Reply #2 on: Fri, 10 October 2014, 08:52:50 »
Yeah, it doesn't pick up either of my control keys?
Offline dante
« Reply #3 on: Fri, 10 October 2014, 11:16:47 »
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #4 on: Fri, 10 October 2014, 11:22:30 »
You prob entered a dipswitch mode by mistake
Offline mattz330
« Reply #5 on: Fri, 10 October 2014, 11:51:55 »
Hey guys,
Just to update you all, I fixed it! Turns out the controller had come lose, I opened it up, pushed the controller back down and all works fine.
« Reply #6 on: Fri, 10 October 2014, 14:36:45 »
Glad to hear you fixed it!
Offline Signature
  • master of puppers
  • snoozing
« Reply #7 on: Fri, 10 October 2014, 15:10:44 »
Nice to see that you regained control
Offline 0100010
  • Not Sure
« Reply #8 on: Fri, 10 October 2014, 20:13:58 »
I only came here to post I thought the title of this thread was birth control stopped working.
« Reply #9 on: Fri, 10 October 2014, 21:32:02 »
im ron burgundy?
Offline jacobolus
« Reply #10 on: Sat, 11 October 2014, 17:38:07 »
When your birth control keys stop working, it’s a big problem.
Offline paicrai
  • mindblank
« Reply #11 on: Sat, 11 October 2014, 19:31:56 »
i really thought this was a thread 4 the pun
THE FEMINIST ILLUMINATI
« Reply #12 on: Sat, 11 October 2014, 19:42:44 »
OP is out of control
/thread
