Author Topic: KBA-nBLTA on eBay  (Read 4456 times)
Offline fl0w3n
KBA-nBLTA on eBay
« on: Fri, 10 October 2014, 15:25:48 »
Was shown these on eBay.
Anyone know about them, what switch, are they worth it or what?
http://m.ebay.com/itm?itemId=121266006222
Re: KBA-nBLTA on eBay
« Reply #1 on: Fri, 10 October 2014, 15:26:51 »
These get posted about once a month, they should be cherry mx blacks and prevoiusly were only $25 shipped.
Offline BlueNalgene
« Reply #2 on: Fri, 10 October 2014, 15:35:20 »
A similar find listed here: http://geekhack.org/index.php?topic=49736.0
Just a quick readthrough of the thread suggests that the board uses pcb mounted black.  The model numbers with nBLT seem to be non-backlit versions of the small keyboard.  The 2KRO is noted, and would probably be annoying.
From the manufacturer's site:http://www.tg3electronics.com/product/backlit-blt-series
« Reply #3 on: Fri, 10 October 2014, 15:53:41 »
I believe that's the TG3 BL-82 but with the touchpad. It's often called the Cop Car keyboard because that board and the TG3 BL-82 were in Crown Victoria police cruisers. They seem to be coming up a lot as the Crown Vics get phased out. I believe they have the splashguard and have MX Black switches. I can't remember if this one is backlit but my BL-82 is backlit with red LEDs.
« Reply #4 on: Fri, 10 October 2014, 23:00:37 »
nBLT means non-backlit. I got a NIB one once from eBay. Keycaps are SP doubleshot.
Offline frosty
  • jukebox hero
« Reply #5 on: Sat, 11 October 2014, 12:37:50 »
Are these vintage blacks?
« Reply #6 on: Sat, 11 October 2014, 12:53:49 »
No. These are relatively new boards.
Offline yuiop
« Reply #7 on: Sat, 11 October 2014, 13:13:57 »
What you get
 - 82 PCB mounted mx blacks
 - Rubber dome spillguard. If you like really stiff switches, you can cut these in pieces and use on other boards.
 - SP doubleshot keycaps, all in top row height except for space bar
 - 1 plate mounted stab.  Space bar wire is in weird length
 - USB cable and some electronic parts you might use ie. trackpad click buttons, 5mm green LED.
 - Plate works pretty well as a lubing station
