Author Topic: Simple Customizer De-Uglification  (Read 5995 times)
Offline pfink
« on: Sat, 27 June 2009, 18:55:35 »
The unattractive Unicomp logo under the LEDs on my black Customizer was starting to bug me. I took the case apart and masked off the LED covers and the rest of the case top with blue painter's tape and newspaper, then sprayed the label with a few thin layers of Rust-Oleum Black Specialty Textured Plastic spray paint. The texture is similar to the case and the color is a shade or two darker but looks closer to the case color under normal room lighting.
Offline wellington1869
« Reply #1 on: Sat, 27 June 2009, 21:20:56 »
very nice job
using: ms 7000/Das 3
Offline watduzhkstand4
« Reply #2 on: Sat, 27 June 2009, 21:27:06 »
indeed that looks really clean =D
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline pfink
« Reply #3 on: Sat, 27 June 2009, 23:03:53 »
Quote from: ripster;99717
Sorry, I forgot to put in how nice you matched the texture.  Did you use this stuff??
I used their Textured Paint For Plastic:
