Author Topic: NEW SITE @ Pexon (need feedback!)  (Read 40665 times)
Offline pexon
  • * Moderator
  • El Jefe of Sleeving
    • Pexon PCs
« on: Sat, 11 October 2014, 12:35:32 »
Hi guys, the new site is live over on http://pexon-pcs.myshopify.com/. We are just waiting on DNS changes to get it to send you on to pexonpcs.co.uk
If you could let me know what you think and if you come across any bugs, that would be epic.
We have some Haloween themed clearance cables as well as cheap Zombie colours up too.
Regards,
James
Offline intelli78
Re: NEW SITE @ Pexon (need feedback!)
« Reply #1 on: Sat, 11 October 2014, 12:38:51 »
Bug: clicking on the Beast Cables banner leads to a password-protected admin page.
Offline cruzin
« Reply #2 on: Sat, 11 October 2014, 12:42:57 »
Looking good! I haven't come across anything yet except for some weird wording on the Colours, coils and FAQ page.
For reference, is a list of paracord colours
Current: Ergodox (Ergo-clears) | Kinesis Advantage (Browns) -- Colemak
Future: HHKB Pro 2 | Maltron L90 | µtron | Axios
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #3 on: Sat, 11 October 2014, 12:49:04 »
What weird wording is that dude? Anything we need to change?
Offline add1ct3dd
« Reply #4 on: Sat, 11 October 2014, 12:55:17 »
MUCH cleaner and modern, good job.
The only thing I don't like is the logo.
It doesn't feel sharp enough (text), and the coloured flairs in the background I think need edges - it's as if they're being chopped off the edges of the image :)
Aside from that, much much better!
I did have a quick question not really site related - is the Poker 2 UK layout? And I don't think you do them with LEDs? :( I have a Cherry Red with Green LED's but its US layout and driving me up the wall :(.
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #5 on: Sat, 11 October 2014, 12:59:44 »
We ate actually looking at getting a new logo professionally done.
Poker 2 are out of stock atm, however we are getting both ISO and ANSI in soonish
« Reply #6 on: Sat, 11 October 2014, 13:39:25 »
I find the different levels and paging a bit confusing. Some low-numbered pages have less items than higher-numbered pages.
Click on "PC Cables". You get four cables, and two categories "PC Cables" and "PSU Cables". Then click "PC Cables" and you get three categories: "All PC Cables", "PC Cables" and "PSU Cables".
If you click the "PSU Cables" or "PC Cables" the view does not change, but if you click "All PC Cables", you are back to having only two categories. And the same four items are shown on all of these pages.
If you click an item, there is only one back button: to "Home", not to the category.
Offline cruzin
« Reply #7 on: Sat, 11 October 2014, 16:19:19 »
The comma is throwing me off. Either "For reference is a list of" or "For reference, there is a list of" works better.
Same thing with the paragraph above it. "For coiled cables we highly recommend"
« Reply #8 on: Sat, 11 October 2014, 17:18:26 »
Very nice site man, Halloween cables cool! Beast cables look sweet too!  :thumb:
Offline FrostyToast
  • Litshoard
« Reply #9 on: Sat, 11 October 2014, 17:37:47 »
How does one order a beast cable?
Quote from: elton5354
Offline Tiramisuu
« Reply #10 on: Sat, 11 October 2014, 18:15:04 »
Can't see clearance on the mobile version on android chrome
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #11 on: Sat, 11 October 2014, 18:31:44 »
cheers for the input guys, it means a lot.
In regards to beasties, check back tomorrow and the option should be there
Offline azhdar
  • Praise the AZERTY god
« Reply #12 on: Sat, 11 October 2014, 18:45:53 »
Look nice , what was wrong with old one ?
Azerty Propagandiste
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #13 on: Sun, 12 October 2014, 06:02:39 »
Just looked a little dated, we always had issues with the checkout too, especially with cards through PayPal
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #14 on: Sun, 12 October 2014, 07:46:53 »
It looks cleaner and much more vibrant compared to the older one.
Very nice :)
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #15 on: Sun, 12 October 2014, 07:50:13 »
Thanks man, making all the changes people have suggested now  8)
Offline abandoner
« Reply #16 on: Mon, 13 October 2014, 15:49:33 »
Looking a lot better than before.
On the sleeving page, the links for paracord and teleios need to be swapped. In the description for teleios there is a typo in the last sentence "Telelios".
« Last Edit: Mon, 13 October 2014, 15:51:43 by abandoner »
Offline Flamingchook
  • There are no dumb questions, only forbidden ones.
« Reply #17 on: Mon, 13 October 2014, 21:10:23 »
Website's looking great. Much cleaner.
On a side note. I like that you've changed the detachable Filco cables to USB A. I've started having some issues with mine and I might order a new one soon.
MX: Filco Majestouch Metalic Blue 104-key w/ MX Brown, JD40 w/ MX Green, ErgoDox w/ MX Blue, GHPad w/ MX Blue. Topre: Realforce 87U 45g. BS: IBM Model M 52G9700 29-OCT-93
Soon™: GH60 w/ 62g MX Clear, [CTRL]ALT 60 w/ MX Green
Offline Badwrench
  • ummmm.....I forgot
« Reply #18 on: Mon, 13 October 2014, 21:49:12 »
Site is looking good.  Not a negative, but hovering over the photos only zooms in in the small window.  I would prefer to either have a larger window or to have a full size photo come up.
Offline add1ct3dd
« Reply #19 on: Tue, 14 October 2014, 08:20:11 »
Thanks for the update, I'll keep watching for the stock - do you know if you'll get any in with LEDs or what switch combinations you plan on getting in?
Ideally I'd just replace the Poker 2 I have (aka sell it), but I'd probably just keep it, and move the new one into my Metal case etc I have from you :).
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #20 on: Tue, 14 October 2014, 12:28:59 »
No need to order another, send an email to: info@pexonpcs.co.uk and we will sort out a replacement  :thumb:
Cheers dude, we will see if we can implement something like that
Ideally I'd just replace the Poker 2 I have (aka sell it), but I'd probably just keep it, and move the new one into my Metal case etc I have from you :) .
We will hopefully be able to get white and black cases, non lit and backlit as well as ANSI and ISO, all depends on what Vortex have for us at the time. All switches including clears fingers crossed!
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #21 on: Mon, 20 October 2014, 15:52:42 »
If I go onto the Silverstone cable section, it gives me the option to add multiple amounts to the cart, but there are no menus to select the cables I would like, and the total is just £0.00 regardless of how many I order.
I see what it is meant to do when I go onto the PSU Extention sets page, but the drop down menus do not appear on the Silverstone page.
It is a very cool looking website though man, I like it :)
« Last Edit: Mon, 20 October 2014, 15:55:21 by katushkin »
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #22 on: Mon, 20 October 2014, 15:58:19 »
Yup, the Silverstone cables haven't been finished yet, the options are all set up though
Offline katushkin
  • Just the guy
« Reply #23 on: Wed, 26 November 2014, 05:14:01 »
You have a section titled "HIDDEN PRODUCT" on your shop page that is empty when clicked on.
Something you aren't telling us? ;)
Offline pexon
  • * Moderator
    • Pexon PCs
« Reply #24 on: Wed, 26 November 2014, 05:23:22 »
Unfortunately not, its just an issue with the app I use for product options that they STILL haven't sorted out yet
