Author Topic: 1391401 or 1386085?  (Read 4343 times)
Offline watduzhkstand4
1391401 or 1386085?
« on: Sun, 28 June 2009, 10:57:45 »
I always thought the number on the back cover of the keyboard should match the sticker on the inside backplate where the keyboard itself is mounted to. Correct me if I'm wrong.
Did he just swapped the internals of a 1386085 into a 1391401 housing?
The board is pretty clean on the outside and decently clean on the inside.
Rivets seems to be ok and I found a spot with hot glue
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
1391401 or 1386085?
« Reply #1 on: Sun, 28 June 2009, 11:42:37 »
I don't know if the wikipedia info is correct but 1386085 is another model.
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline sandy55
1391401 or 1386085?
« Reply #2 on: Sun, 28 June 2009, 11:43:04 »
Quote from: watduzhkstand4;99759
== snipped image ===
No, he didn't.
1386085 is a p/n of an assembly of a back plate and an actuator panel.
some of my 1391401s do also have a back plate assembly with exactly same p/n as yours. Have not yet checked all of my Ms though.
Some of 1391406(UK model) might have a back plate numbered as 1386719.
According to one of my MCA mates, the number 1386719 is also written on the back label in small fonts along with 1391406.
1391401 or 1386085?
« Reply #3 on: Sun, 28 June 2009, 11:48:46 »
Quote from: sandy55;99767
No, he didn't.
thanks for the input! I'm not worried now =D
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline wellington1869
1391401 or 1386085?
« Reply #4 on: Sun, 28 June 2009, 13:06:03 »
interesting pics. One of these days I have to check my own rivets. Hot glue seems to be a popular alternative/substitute fix for broken rivets.
using: ms 7000/Das 3
1391401 or 1386085?
« Reply #5 on: Sun, 28 June 2009, 13:09:48 »
Quote from: wellington1869;99778
I don't know anything about what to use to fix rivets but it seems like most of mine are still intact. I also never knew that the font color on the 'alt' keys were green, so is the 'SysRq' labeled in the front side of the keycap on the 'Print Screen' key.
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline ch_123
1391401 or 1386085?
« Reply #6 on: Sun, 28 June 2009, 14:15:54 »
On my Model F, even the plastic casing had it's own model number... IBM seems to be rather meticulous about this stuff.
To draw attention to the fact that SysRq is Alt+PrtSc.
« Last Edit: Sun, 28 June 2009, 14:24:26 by ch_123 »
Offline MANISH7
1391401 or 1386085?
« Reply #7 on: Mon, 29 June 2009, 19:31:17 »
Does your model m have support wires on the enter key and plus key in the number pad? Maybe you'd have to pop off the enter key to see.Thanks.
