Author Topic: Looking for a dust cover like Filco's that will fit a Deck Hassium Pro  (Read 1195 times)
Offline Splashy
    • http://www.gali-nir.com
I have a Deck Hassium Pro keyboard and I'm looking for a dust cover like Filco's that will fit the Deck keyboard.
Unfortunately Filco's cover doesn't fit the Deck because of the extra keys above the numpad on the Deck.
If there's no cover like Filco's that will fit the deck, a simple cover will do.
I don't need any of the "keyboard roofs", I already have one and I mainly use it to protect the keyboard from my cat should it decide to walk on the keyboard but it doesn't fully protect the keyboard from dust.
Any ideas would be appreciated.
TIA.
« Last Edit: Sun, 12 October 2014, 09:55:49 by Splashy »
