Author Topic: Looking for Backlit Steam logo Keycap?  (Read 5532 times)
Offline pufnstuf
« on: Sun, 12 October 2014, 16:00:29 »
I've been searching everywhere can't seem to find anyone who sells a backlit steam logo keycap. I would like it so I can replace my windows key. Has anyone seen one or know of a site that will do custom backlit keycaps? I have cherry MX switches.
« Last Edit: Sun, 12 October 2014, 16:02:19 by pufnstuf »
Re: Looking for Backlit Steam logo Keycap?
« Reply #1 on: Sun, 12 October 2014, 16:19:38 »
Welcome to Geekhack!
I can't recall having seen any Steam logo keycaps.  Especially not backlit ones.  Although game theme ones can be found, like Portal.
Is your Windows key 1.25x?  Something that people will need to know.  Some keyboards have 1x Win keys.
Good luck with your search!
Offline pufnstuf
« Reply #2 on: Sun, 12 October 2014, 16:43:45 »
Thank you! Glad to be here! My windows key is 1x1 Ive been looking around for a while haven't found anything. I just ordered backlit portal keycaps for my alt keys tho and a backlit counter-strike key to replace my esc key.
« Reply #3 on: Sun, 12 October 2014, 16:46:48 »
1x makes it marginally easier, but still doesn't help that I don't think anyone makes them.
MAX Keyboard probably has the largest range of backlight-friendly custom keycaps I have seen, but alas no Steam logo.
Maybe email them and see if they might consider making one.
Offline pufnstuf
« Reply #4 on: Sun, 12 October 2014, 16:49:52 »
Funny you say that I just ordered the portal keycaps from them and left a comment in my order about making it. There is no one that makes custom backlit keycaps? I know WASDkeyboards makes custom keys but they don't offer backlit. I'm assuming cause its to expensive to manufacture?
Offline heedpantsnow
  • Old enough to know better
« Reply #5 on: Sun, 12 October 2014, 16:59:06 »
Printing a logo on an existing cap is many times cheaper than making it with two plastics to make the light shine through.
I'm back.
Offline pufnstuf
« Reply #6 on: Sun, 12 October 2014, 17:33:59 »
I don't care id gladly pay double to price for it. You'd think with steam machines coming out soon people who will be using steam os would want to buy keycaps with steams logo on it. Maybe companies are afraid of copyright issues with the logo.
Offline esoomenona
  • Gnillort?
« Reply #7 on: Sun, 12 October 2014, 17:39:55 »
« Last Edit: Fri, 04 September 2015, 11:27:37 by esoomenona »
« Reply #8 on: Sun, 12 October 2014, 17:45:07 »
Sometimes, it's not about how much you'd pay, but about how many other people will pay that, and whether it's a good idea to even invest in the first place. Steam is a trademark logo. You can't just make keycaps of it as you please. This makes it harder for keycap manufacturers who even have the ability to make these kinds of caps to make one at all.
The Portal "logo" might be trademarked too.  It is instantly recognisable icon of the game.
Offline esoomenona
  • Gnillort?
« Reply #9 on: Sun, 12 October 2014, 18:19:27 »
« Last Edit: Fri, 04 September 2015, 11:25:57 by esoomenona »
« Reply #10 on: Sun, 12 October 2014, 19:07:43 »
I don't doubt it is, rowdy. Not everything that exists has been created legally. I never said that it wouldn't or couldn't be done.
Exactly!
What I was implying is that if Valve had granted permission to make Portal logo keycaps (as available on the MAX website), then they very well might also grant permission to make Steam logo keycaps.
Offline esoomenona
  • Gnillort?
« Reply #11 on: Sun, 12 October 2014, 20:03:32 »
« Last Edit: Fri, 04 September 2015, 11:25:24 by esoomenona »
« Reply #12 on: Sun, 12 October 2014, 20:04:54 »
Are you sure they granted them permission though?
No idea, but they have big enough balls to make the molds, create the keycaps, and then sell them in their online store.  I don't imagine they would do that if they did not have permission.
