Author Topic: Convex 1,25u keycap? (MX mount)  (Read 2762 times)
Offline ksm123
« on: Mon, 13 October 2014, 05:29:45 »
Have anyone of you ever seen convex 1,25u keycap from spacebar/modifiers row?
How about convex DSA 1u keycap?
I Poland we are taught to press AltGr with right thumb (AltGr-o and AltGr-l are very common combinations). Convex AltGr would be easier on the thumb. Do you know which manufactures are able to produce it?
Offline P3TC0CK
Re: Convex 1,25u keycap? (MX mount)
« Reply #1 on: Mon, 13 October 2014, 08:39:55 »
Even with their new price changes it wouldn't cost too much to get it 3D printed on Shapeways if it's just single key so that's an option if you can't find a manufacturer. Just design the key or get someone to do it for you.
petcock
[pet-kok]
noun
1. a small valve or faucet, as for draining off excess or waste material from the cylinder of a steam engine or an internal-combustion engine.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Mon, 13 October 2014, 08:48:25 »
Only seen them on Filco Minila. Someone makes them, but haven't seen them for sale separately.
Offline esoomenona
  • Gnillort?
« Reply #3 on: Mon, 13 October 2014, 08:49:02 »
« Last Edit: Fri, 04 September 2015, 11:25:10 by esoomenona »
Offline Tasker
    • Gizmo Bazaar
« Reply #4 on: Wed, 15 October 2014, 05:04:32 »
I've actually recently been putting together some 3D models on my Shapeways shop for 1x1.25 keycaps (and some other sizes too).
Here's a flat top row 1 version http://shpws.me/wmcM
If you had a design in mind I could pretty easily put together a custom convex row 1 (spacebar row) version for you.
