Author Topic: Removing anodizing from aluminum case  (Read 1893 times)
Offline Dakine234
  • Live, Love, ALOHA
« on: Mon, 13 October 2014, 16:24:02 »
Anyone have any experience or try removing the anodizing from an aluminum case?  I've read that aluminum can be unanozided using a degreaser and a brush but am not sure if that works.  Any help or input is appreciated, mahalo!
Poker II mx blues + Custom Poker X with mx clears, blues and old blacks
Offline BlueBär
Re: Removing anodizing from aluminum case
« Reply #1 on: Wed, 15 October 2014, 05:43:48 »
If you go to an anodizing shop they can usually deanodize it for you afaik.
Offline Dakine234
  • Live, Love, ALOHA
« Reply #2 on: Wed, 15 October 2014, 21:11:30 »
Thanks for the info!
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #3 on: Wed, 15 October 2014, 23:48:02 »
Degreaser will not work to my knowledge.  The anodized layer is a chemical conversion process.  Mechanical removal is the only way.  The biggest reason to go with a shop that does anodizing is because they already have to tooling required to do this without destroying the part.  The same process is essentially done before the part is anodized anyway because anything will screw up the results including oils from just touching the part with bare fingers.  Though that is taken care of in one of the dips before the actual anodize is done.  Anodizing aluminum with color is essentially corroding the part a determined and very exact amount and adding a pigment to the process.  This is why custom colors are so expensive.  The shop has to do an entire tank worth of mix just for your part.  But when doing a run of multiple parts they get many parts per batch of mix.
Also, the only difference between "hard" and "soft" anodizing is the depth of penetration.  The layer of corrosion that makes up the anodize is actually harder than the base material.  This is where the "hard" and "soft" terms come from.  The deeper the corrosion layer the higher the new surface hardness is.  Though it will still dent when dropped on concrete.
Offline Dakine234
  • Live, Love, ALOHA
« Reply #4 on: Thu, 16 October 2014, 04:53:55 »
Thanks for the info!  I accidentally double posted this thread and got similar answers to yours in the other thread.  I decided to go against removing the anodizing and will look for another case instead, think its better than messing up a perfectly good case.  Thanks again!
