Author Topic: What paint do you all recommend to paint the quickfire tk to white?  (Read 17639 times)
Offline agent181
Like the title says I want to paint the quickfire tk possibly into a dual tone color with black already on and white but what color do you all recommend to contrast it right.  I want a matte finish like the black already on though.
Offline awhitedev
Re: What paint do you all recommend to paint the quickfire tk to white?
« Reply #1 on: Thu, 16 October 2014, 16:55:57 »
Black and white could look good. Are you doing stripes? I think most people do one solid color for the case and contrast it with a different color set of keycaps. Not sure if the TK has a rubber coating like the TKL does but if it does I would recommend completely sanding that off before painting too. The results will be better.
