Author Topic: Ebay M with issues, return?  (Read 2512 times)
Offline Vxeheme
« on: Tue, 30 June 2009, 19:48:57 »
I purchased on Ebay, from a newer clicky vendor with 100% feedback who specializes in Model M's, a 1987 1391401 for $30.95, which was advertised as "perfect condition inside and out. It has been thoroughly tested and is in perfect working order."  It is clean and looks nice, but has 19 keys (mostly grouped in 2's and 3's) which don't click and which do not produce a letter when pressed unless I really mash on them.  My wife thought those keys didn't work at all, after multiple attempts, to illustrate the firmness required.  It is impossible to touch-type.
I have read that the plastic rivets cause trouble, and can be replaced with screws & nuts.  Is this the trouble they cause?  Failure to click/register key presses?
Should I keep this keyboard at that price and try to fix it (if it is rivet trouble), or insist on a refund as not being as advertised?  After paying shipping two ways, I'll lose $30 and still not have a keyboard, but I don't feel it was advertised honestly.
Thanks for your time.
Offline MANISH7
« Reply #1 on: Tue, 30 June 2009, 19:57:18 »
it's only fair that the buyer accommodate you. write to him what you've indicated here. request for a refund and ask him to consider letting go of the keyboard given its significantly defective condition so that you don't have to pay for return shipping as you've already paid $15 the first time. if he asks you to ship it back, then return shipping should cost no more than $8 via FedEx (that's how much I paid to ship a model m from philly to boston). so you'll lose $25. i personally am not comfortable nor want to spend the time repairing / modding the keyboard.
Offline wellington1869
« Reply #2 on: Tue, 30 June 2009, 20:00:04 »
Quote from: Vxeheme;100326
no, this isnt the symptom they cause. it sounds like you got a bum board.
no, the price you got it for is okay, but its not an amazing deal and you should be able to get that price again without too much trouble.
if it was not advertised honestly (and it sounds like it was not), the seller should really pay shipping both ways (you'd be in your rights to insist) (or atleast one way) it seems to me. Most reasonable sellers are willing to do that once they understand the problem and accept that there is a problem.
You can also always open a case with paypal for a refund after trying to get the seller to cooperate; i've done that once and paypal was very quick and very responsive and I got my full purchase price back.
using: ms 7000/Das 3
Offline ch_123
« Reply #3 on: Tue, 30 June 2009, 20:06:14 »
On a more practical end of things, did you try removing and reseating the keycaps (well, both the removable keycap and the steam underneath it) of the keys in question?
« Reply #4 on: Tue, 30 June 2009, 20:08:02 »
Quote from: ch_123;100334
lol, this is a good point actually. before you raise hell with the seller, pop the keys off and reseat them. Badly seated keys on an M will cause some of the symptoms you're describing (no click, weird presses, etc). Make sure the spring goes straight up into the stem (and not at an angle) when you click the key back on.
Offline ch_123
« Reply #5 on: Tue, 30 June 2009, 20:10:38 »
Just to add to that, from experience, I find that the best way to ensure the key/stem goes back in the right way is to hold the keyboard upside-down and let the springs fall against the top of the shaft that they rest in (or bottom if you are look at it upside down). That way you ensure the spring matches up nicely with the notch for the spring underneath the key/stem.
« Reply #6 on: Tue, 30 June 2009, 20:12:05 »
Quote from: ch_123;100337
Just to add to that, from experience, I find that the best way to ensure the key/stem goes back in the right way is to hold the keyboard upside-down and let the springs rest against the top of the shaft that they rest in (or bottom if you are look at it upside down).
ya, or lift the front edge of the keyboard so the springs plop backwards. they're more straight that way when the key goes on.
Offline watduzhkstand4
« Reply #7 on: Tue, 30 June 2009, 20:21:07 »
Did you purchase from clicky0131 on ebay? I got one from him just now and had the same symptoms as you did. For the keys that doesn't click, try to reseat the whole key. That's what I did to the ones that didn't click for mine and it works great right now. Hope this helps!
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline Vxeheme
« Reply #8 on: Tue, 30 June 2009, 20:46:43 »
Quote from: watduzhkstand4;100343
Yes, from clicky0131, and the reseating of both outer/inner caps seems to work!  I tried it on 4 keys which now work properly.  My wife is making me go to bed (gotta get up early), so I can't finish the rest of the keys just now.
Thanks for all of the quick responses, you folks are on the ball.  I'll post tomorrow after work when I can work on it more.
« Reply #9 on: Tue, 30 June 2009, 20:50:49 »
Quote from: Vxeheme;100346
You're welcome! Glad that it helped!
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline Xuan
« Reply #10 on: Tue, 30 June 2009, 22:06:03 »
shwishh, shwishhh... (whip soud) :D
Good luck with the rest! Have buckling dreams.
Offline itlnstln
« Reply #11 on: Wed, 01 July 2009, 07:10:18 »
Sleep... what do wives know, anyway?
Offline ch_123
« Reply #12 on: Wed, 01 July 2009, 07:26:48 »
Should have brought the keyboard to bed =P
Offline Vxeheme
« Reply #13 on: Wed, 01 July 2009, 18:43:19 »
I was able to fix all of the keys during lunch today.  When I came home after work and hooked it up to test, however, several keys had lost their click again and I had to rereseat them.
So I'm not declaring victory yet.
Offline talis
« Reply #14 on: Wed, 01 July 2009, 19:03:55 »
I'd still get in touch with the seller, you've spent a portion of your own time to repair it.
I think a lot of sellers believe they can hide behind the anonymity of EBay, and and not always deliver what they promise.  And I think of lot of buyers accept sub-standard purchases with no questions because of it.  The feedback function holds a huge amount of power over the sellers, don't hesitate to give negative feedback if they don't give you satisfaction.
If they promised a tested, working keyboard, there's no reason to accept less.  Even if you can fix it, you've spent a portion of your time to do so.
Offline Vxeheme
« Reply #15 on: Wed, 01 July 2009, 19:31:45 »
Quote from: ripster;100563
Does anyone else here think that clicky0131 isn't a perfectionist?
Perhaps not, but he apologized and said he'd pay shipping to take it back and fix it, or trade for another (after my initial complaint yesterday), so he seems honest.
Offline talis
« Reply #16 on: Wed, 01 July 2009, 20:40:12 »
Send him a link to geekhack, maybe he'll learn the right way to clean and re-assemble a keyboard =P.
« Reply #17 on: Wed, 01 July 2009, 21:26:13 »
Quote from: Vxeheme;100560
Yea even now my caps lock key and my / key on the numpad is not clicking but I'm fine with it because I don't use the caps lock key too much and there are 2 of the / keys so I'm not complaining. But did he even return a feedback for you on ebay yet? He still didn't give me a feedback yet, about to message him about that!
KEYBOARDS
SOLD
HHKB L-2
Dell AT101W
Offline Vxeheme
« Reply #18 on: Fri, 10 July 2009, 18:44:43 »
My keyboard has been fine since the reseating of the key stems.  My other keyboards feel defective without the click.
Thanks for the help.
