Author Topic: Looking for a new mouse pad with wrist rest  (Read 4731 times)
Offline Boozebreath
« on: Wed, 15 October 2014, 16:25:17 »
Anyone know good cloth gaming moues pad with a wrist rest?  Only one I can find is the Razer Vespula, no idea if it is any good.  Unless I am better off getting a Steelseries QcK and finding a separate wrist rest.
If anyone could recommend or list some good ones it would be appreciated.
Offline exit
Re: Looking for a new mouse pad with wrist rest
« Reply #1 on: Thu, 16 October 2014, 05:04:19 »
Roccat Alumic, hands down better than Vespula judging by reviews. (aluminium surface)
Edit: Read multiple sources saying that the aluminium surface of the Alumic is superior to Vespula's overpriced plastic.
« Last Edit: Thu, 16 October 2014, 06:24:29 by exit »
Offline Boozebreath
« Reply #2 on: Thu, 16 October 2014, 16:08:56 »
Doh! didn't realize the Razer Vespula was plastic, so it rules that out.  I did check out the Roccat Alumic because I never heard of it, looks pretty cool but spendy for a mouse pad.  I may try one in the future but for now I just was a good yet cheaper cloth pad.  So far that only leaves me with the SteelSeries QcK, least its only $10.
Offline sobe
« Reply #3 on: Thu, 16 October 2014, 18:23:51 »
I switched to the PureTrak Talent (white special edition to match setup) a while back from the QcK Heavy and QcK+ and it's much smoother and I prefer it myself. They are $16 right now directly from PureTrak.
(For reference, I've been using the Zowie FK1 since it arrived in the mail yesterday, but have been running a Logi G400 with great results on the Talent)
Lately I have been looking at the Artisan Hayate Soft though, but with all the options Artisan offers, I'm weary of the smooth gliding in one direction and slightly heavy in the other direction. Artisan seems to be the go-to for quality pads if you are willing to spend for it. I've also seen Allsop getting some love.
Offline Boozebreath
« Reply #4 on: Thu, 16 October 2014, 18:51:00 »
Currently trying out an allsop I borrowed actually.  It's okay but the memory foam wrist rest makes my wrist hot and sweaty.  So I should probably rule out memory foam rests.
Offline exit
« Reply #5 on: Fri, 17 October 2014, 06:51:37 »
Well you made a thread saying you wanted one with a wrist rest, i guess you changed your mind?
Offline davkol
  •  Post Editing Timeout
« Reply #6 on: Fri, 17 October 2014, 12:57:05 »
Any mouse pad + Allsop Wrist Assist.
Offline Boozebreath
« Reply #7 on: Fri, 17 October 2014, 22:50:38 »
No but I still said I was open to getting a wrist rest separate in my first post, more options never hurt.
