Author Topic: Not that I'm a connie-sewer, but I don't recognize this IBM keyboard...  (Read 6114 times)
Offline Shawn Stanford
The Brat Prince of COBOL
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #1 on: Wed, 01 July 2009, 06:30:04 »
It looks like some later variant of the Model M with the Windows keys. But that's just a guess; I've never seen one of those before...
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #2 on: Wed, 01 July 2009, 06:33:32 »
If that's an IBM, it must be rebranded - the L-shaped Enter and short Backspace point more towards East Asian origins.
'connie-sewer' for 'connaisseur', that took me a second...
« Last Edit: Thu, 02 July 2009, 01:51:16 by keyb_gr »
Offline timw4mail
    • https://timshomepage.net
« Reply #3 on: Wed, 01 July 2009, 07:01:08 »
Quote from: keyb_gr;100408
'connie-sewer' for 'connoisseur', that took me a second...
Wrong, its just the larger ANSI Enter.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
« Reply #4 on: Wed, 01 July 2009, 07:06:08 »
I thought the 'dropped' cursor T was interesting; I don't remember seeing that before. Is it a PS/2 connection and buckling spring, or something else?
Offline huha
« Reply #5 on: Wed, 01 July 2009, 07:38:26 »
I guess it's not an IBM keyboard at all.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline timw4mail
« Reply #6 on: Wed, 01 July 2009, 07:52:18 »
Quote from: Shawn Stanford;100416
The dropped T is common in "compact" 104 key layouts. Its dropped to remove that much space from the width of the keyboard, usually subtracting from the spacebar.
Offline ch_123
« Reply #7 on: Wed, 01 July 2009, 08:05:56 »
Quote from: Shawn Stanford;100404
I'd be almost 100% certain that that is not an IBM board, although I remember seeing it while searching for a Model F on ebay, so maybe that's where you found it?
« Last Edit: Wed, 01 July 2009, 08:10:05 by ch_123 »
Offline sandy55
« Reply #8 on: Wed, 01 July 2009, 08:29:30 »
Probably it's a KB6551 made by NanTan sold as Chicony, Nantan, Zeos and more ( FCC ID FMAKB6551).
check  Scarry's listing. he often lists this one on eBay.
Mostly simplified alps white on a plastic face plate. not sure if real complicate alps/metal face plate version exist or not.
« Reply #9 on: Wed, 01 July 2009, 12:38:56 »
Quote from: ch_123;100431
Could be, I'm not in a position to check right now due to restrictions at work.
Offline sandy55
« Reply #10 on: Thu, 02 July 2009, 08:50:55 »
found an Unitek version which is tooooo much expensive even if it happened to have real alps.
Offline itlnstln
« Reply #11 on: Thu, 02 July 2009, 08:52:35 »
I would get that if I were still into Alps.  Not the $99 one, though, but I would be on the lookout for a cheaper one.  I like that smaller layout.
« Reply #12 on: Thu, 02 July 2009, 20:31:13 »
I also like its enter key. The one thing that can irritate me a little on the Model M is the fact that I often hit the \ key instead of the Enter key after using typewriters and an old Gateway2000 with an AnyKey (I wish I still had it!).
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #13 on: Wed, 16 September 2009, 20:24:17 »
Quote from: timw4mail;100414
Nope, that is the backwards-L Enter. And the |\ is between += and backspace, as can be seen from the photo. That pretty much proves it not to be an IBM.
EDIT: at least, not an IBM from after the victory of the Model M over the Model F.
EDIT: Here's one with that layout, although the keys are the wrong color:
http://www.costar.com.tw/products01/info.php?p_id=46&p_sid=32
« Last Edit: Thu, 17 September 2009, 11:02:17 by quadibloc »
Offline chimera15
« Reply #14 on: Tue, 22 September 2009, 15:36:13 »
Quote from: sandy55;100433
I bought that one. ;)
Although I guess he said he had another one.
It has real simplified alps switches.
http://geekhack.org/showthread.php?t=5815&highlight=KB-6551
« Last Edit: Tue, 22 September 2009, 15:38:31 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline fkeidjn
« Reply #15 on: Wed, 23 September 2009, 07:13:54 »
The Unitek one that I have uses original Alps, and looks like the one in the picture.
Kinesis Keypad - Filco FKBN104M/EB - Unitek space-saver - Acer 6511-TW - Apple Extended II (M3501) - Scorpius M10 - Cherry G80-1800, AT - SGI Granite - vintage Fujitsu - IBM Model M, 101 and mini - Model F, 84-key AT - Dell AT101W - Northgate 101
