Author Topic: marking home keys  (Read 5550 times)
Offline gcb
marking home keys
« on: Thu, 16 October 2014, 18:30:43 »
bought a beautiful penumbra set from binge and now i am going crazy because the keys do not have the little nubs on the home keys.
i'm using qwerty so i will put them on F and J as usual.
I'm considering options:
A) a drop of epoxy
B) saw a stripe like  jaymatter did
C) rape this beautiful set and use caps from another set that have nubs. or maybe even a metal cap for those two keys.
any better alternatives?
« Last Edit: Thu, 16 October 2014, 18:34:35 by gcb »
Offline NeedAFix
  • Ten Seconds until Midnight
Re: marking home keys
« Reply #1 on: Thu, 16 October 2014, 18:39:37 »
Do what I did and use a dremel; Get one of the thin sand wheels and just etch your design into the top :)!
The Bird of the Hermes is my name,
eating my wings to make me tame.
Offline gcb
« Reply #2 on: Thu, 16 October 2014, 18:44:32 »
that is almost option B above. i like the epoxy one better so far because i am pretty sure the mess i will make with a dremel :(
did you manage to make precise geometric shapes on yours?
Offline NeedAFix
« Reply #3 on: Thu, 16 October 2014, 18:51:32 »
Nah I just took the paint off the sides, but if you use a thin enough sanding blade you could do something interesting.
I don't know about Advanced Geometry, that is more or less something for molds (laser etch detail is hard to do by hand).
You can see what I did in this thread: http://geekhack.org/index.php?topic=64264.0
Offline gcb
« Reply #4 on: Fri, 17 October 2014, 17:03:15 »
Ah ok, i finally understood what you meant.
i'm looking for something tactile. i don't have lights and the keyboard is almost under the desk at most times...
Offline NeedAFix
« Reply #5 on: Fri, 17 October 2014, 22:51:51 »
Yeah, I'd still say use a dremel and figure out what kind of little icon you want on the keys (make it kind of simple) and just grind it in.
Why not? :P
Even easier to do when you have extra sets of keys laying around.
Offline yasuo
  • spanengan puyeng newbie
Logitech MK220 Colemak DH
Offline NeedAFix
« Reply #7 on: Fri, 17 October 2014, 22:58:11 »
Yeah, could use some kind of grip sticker or thing such as that.
Snowboarding / Hockey grip tape, maybe? The problem with using anything that has adhesive, though, is the residue it leaves and during hard gaming sessions tape wouldn't cut it.
How does the dot stick on; I guess instead of making a raised bump you could make holes via a dremel.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #8 on: Fri, 17 October 2014, 23:00:52 »
I would use a drop of clear fingernail polish.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #9 on: Fri, 17 October 2014, 23:05:33 »
If fingernail polish doesn't last you could mix up some epoxy resin and then use a hypo needle to neatly put a drop on the key. Should last forever once it cures.
« Reply #10 on: Sat, 18 October 2014, 10:08:23 »
Drill a tiny hole. Insert a piece of plastic rod in it. A drop of glue on the inside.
Offline NeedAFix
« Reply #11 on: Sat, 18 October 2014, 11:02:59 »
That gave me the idea of Drilling a filling area (or creating a keycap with a recess on top) that you could put metals into, copper or some such -- gold leaf?
Offline gcb
« Reply #12 on: Tue, 21 October 2014, 20:31:39 »
i'm busy with other stuff, but i think i will go with a compilation of the ideas here:
'drill' (more like scrap) a very small half sphere out of the top of the key.
drop with a toothpick a dab of epoxy.
the little recession would make for a better surface tension holder for the drop of epoxy to cure round instead of flattening all over the key. and also hopefully help it stay in place with time/use.
when i finally can get around to do it, i will post results.
Offline Melvang
« Reply #13 on: Tue, 21 October 2014, 20:51:18 »
When you do it, spin the drill bit with your fingers.  If you don't have a drill bit made fro plastics (acrylic and brass are horrible with this), you run the risk of the drill bit grabbing and essentially threading the cap at the same pitch as the flutes on the drill bit.
I have seen this happen with acrylic and it can actually pull the piece being drill out of the vise on the drill press.
Offline Oobly
« Reply #14 on: Wed, 22 October 2014, 01:30:00 »
This sounds like a very good plan. I would stay clear of nail polish since the acetone can melt ABS.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline jackalope
  • Now with 20% more soul.
« Reply #15 on: Wed, 22 October 2014, 02:17:49 »
Couldn't you flip the key around so you could find it by feel, and then you wouldn't have to destroy a key.
eh o well
« Reply #16 on: Wed, 22 October 2014, 03:20:56 »
Or, dermal a little crater and put a small bearing in it?
Offline gcb
« Reply #17 on: Wed, 22 October 2014, 12:38:01 »
lol i tried. im not very keen on naming key shapes and sizes... but this set is simetrical on the home row.
that is interesting. and i have plenty... if the epoxy do not form a good round blob i will probably go that route
Offline Tiramisuu
« Reply #18 on: Wed, 22 October 2014, 16:23:03 »
I've been thinking of using the was keycaps with a customer layout.   Sadly abs.    Can anyone confirm that was custom sets have home key bumps?
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
« Reply #19 on: Wed, 22 October 2014, 16:28:06 »
Most DCS sets do AFAIK
