Author Topic: Help! Not sure if IBM Model M compatible with computer  (Read 2354 times)
Offline cowa
« on: Sat, 18 October 2014, 00:21:10 »
Recently got very interested in the wonderful world of mechanical keyboards and decided to look at the legendary ibm model m keyboard.  I bid on one thinking it would come with a ps/2 cord, compatible with my computer, but after later looking more closely at it saw it did not.  Looking into the date of manufacturing I realized it isn't modern enough for ps/2.  I've done a lot of intense googling and no one really seems to talk about it much.  Can anyone help?
IBM Model M 1987 1391401
http://www.ebay.com/itm/EXCELLENT-IBM-MODEL-M-CLICKY-KEYBOARD-PART-1391401-O-8/191371542425?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D25410%26meid%3D716e364368d247daafb3741d5bf4fd88%26pid%3D100005%26prg%3D10672%26rk%3D2%26rkt%3D6%26sd%3D151443403724&rt=nc
Offline inoxify
Re: Help! Not sure if IBM Model M compatible with computer
« Reply #1 on: Sat, 18 October 2014, 00:31:46 »
I Did the same thing last week, this is a terminal M, you will need a teensy and Soarer's Converter
http://geekhack.org/index.php?topic=17458.0
Offline ComradeSniper
  • HHKB Pro
« Reply #2 on: Sat, 18 October 2014, 00:47:41 »
Nope, not a terminal M, just one of the earlier model Ms with a DIN5 cable. You can get a DIN5 to PS/2 adapter for cheap on amazon.
Offline inoxify
« Reply #3 on: Sat, 18 October 2014, 00:50:25 »
Oh nice, disregard my post then you got lucky if you win it!
Offline FreeCopy
« Reply #4 on: Sat, 18 October 2014, 01:12:39 »
Another option if you want to spend the extra money is to get the standard detachable ps2 cable through Unicomp.
Good luck! Let us know if you get it.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #5 on: Sat, 18 October 2014, 01:45:58 »
I just ordered a DIN5 to PS/2 convertor from Amazon, it was only $3.99 with Prime Two-Day. Since DIN5 uses the same signal as PS/2 (Mini DIN-6), you don't need any fancy convertors, just a cheap one.
« Reply #6 on: Sat, 18 October 2014, 03:38:01 »
Yeah, that.  Plus a PS/2 to USB adaptor if you want to use it on a USB-only computer.
Or if it has SDL port you can go straight from SDL to USB:
http://www.ebay.com/itm/BEIGE-USB-to-SDL-6-Pin-6ft-IBM-Lexmark-Unicomp-Model-M-Clicky-Keyboard-Cable-NEW-/271470078682?pt=LH_DefaultDomain_0&hash=item3f34e0aada
http://www.ebay.com/itm/USB-to-SDL-6-Pin-6ft-IBM-Lexmark-Unicomp-Model-M-Clicky-Keyboard-Cable-NEW-/271367683396?pt=LH_DefaultDomain_0&hash=item3f2ec63d44
My Model M 51G8572 I am currently using with one of the above black cables on my Mac.
« Reply #7 on: Sat, 18 October 2014, 08:30:37 »
I second this suggestion. Orihalcon's cables are pricey but beautifully built and work great.
- D Trump 2026-10-24
« Reply #8 on: Sat, 18 October 2014, 10:34:08 »
they also make use of the ID innovations ps/2 to usb adapter which is my favourite of commercial options.
The cheapest way would be to open it up and put in an arduino pro micro running soarer's converter code, but it requires some DIY and some knowhow.
« Reply #9 on: Sun, 19 October 2014, 04:55:17 »
Trivia: My Orihalcon cable (SDL to USB) cost more than both my Model M put together!
