Author Topic: (ebay) CM Storm QFR MX Green  (Read 2057 times)
Offline dante
« on: Sun, 19 October 2014, 20:34:50 »
Offline berserkfan
Re: (ebay) CM Storm QFR MX Green
« Reply #1 on: Sun, 19 October 2014, 21:07:34 »
I am truly curious as to how much a new CM QFR w greens will fetch in the open market. These don't seem easy to move on geekhack, but maybe the general public begs to differ.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #2 on: Mon, 20 October 2014, 00:22:59 »
So you think Geekhackers hate these keyboards for some reason?
They're at least using the GREEN-GOD cherry switches which is near perfection in the world of Cherry hardware, so that should be worth something to someone out there.
Offline xmagusx
  • QWERTY is hateful.
    • The Ergonomic Zone
« Reply #3 on: Tue, 21 October 2014, 08:03:27 »
More likely they're just seen as "entry-level" or just not what people here are looking for with regard to their regular use board. Plus MX Greens have the same problem as MX Blues and buckling springs -- they're loud, and that means that even if you were willing to buy it to replace the ****ty Dell rubber dome you were using at work, your co-workers would remove your hands by the end of the first week you used it.
Offline berserkfan
« Reply #4 on: Tue, 21 October 2014, 08:56:58 »
ok, at $66, still less than geekhack price.
