Author Topic: Software for multiple program instances  (Read 2040 times)
Offline Naweo
« on: Mon, 20 October 2014, 14:02:04 »
Hello, currently I am using sandboxie to open multiple instances of programs but it seems that the more instances I open, the more lag I get, and this is likely a software issue.
Does anyone know programs similar to sandboxie which could handle the job better?
Offline Doyniish
  • Good you
    • Power Hour Playlists
Re: Software for multiple program instances
« Reply #1 on: Mon, 20 October 2014, 22:00:58 »
Sounds more like a memory issue.
Offline Oobly
« Reply #2 on: Tue, 21 October 2014, 05:52:45 »
What's preventing you from opening multiple instances of the program without sandboxie? If you really want application isolation, Bufferzone Pro is another one you can try. If you're running a lot of instances, it could well be a memory issue causing the lags, depending on how sanboxie handles reserving memory per instance.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
