Author Topic: [video] Hand-wiring a custom keyboard  (Read 6006 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« on: Tue, 21 October 2014, 07:06:00 »
some more details:
- at the beginning I'm making ghetto green (blue sliders, black springs)
- the whole process took approx 8 hours (in 2 days)
- the controller is a teensy 2
- firmware is hasu's TMK
- the bottom plate is steel, the switches plate is aluminum, the sides are made of wood (it is called Elf-board)
- the keycap set is DSA Retro
- the glue I use for the USB port is a fast-curing time epoxy glue
- the soundtrack is: #1 Kotetsu Jeeg opening theme, #2 Tank! by Yoko Kanno
if you have more questions don't hesitate to ask!
ENJOY!
« Last Edit: Wed, 22 October 2014, 08:25:38 by Matt3o »
Offline swill
  • builder & enabler
    • swillkb.com
Re: [video] Hand-wiring a custom keyboard
« Reply #1 on: Tue, 21 October 2014, 07:19:48 »
Nice work
« Reply #2 on: Tue, 21 October 2014, 07:25:05 »
That was really well edited and fun to watch  :thumb:
Offline feizor
« Reply #3 on: Tue, 21 October 2014, 07:36:39 »
Thanks for sharing this with us. You make it look so easy and effortless!
Nice soundtrack too :)
« Reply #4 on: Tue, 21 October 2014, 07:38:33 »
I have a question: When I grow up, can I build keyboards like you?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #5 on: Tue, 21 October 2014, 08:01:50 »
LOL! all it takes is to start
Offline Tiramisuu
« Reply #6 on: Tue, 21 October 2014, 11:57:24 »
Saw this on reddit and was very motivated.
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline esoomenona
  • Gnillort?
« Reply #7 on: Tue, 21 October 2014, 12:04:02 »
« Last Edit: Fri, 04 September 2015, 09:55:19 by esoomenona »
« Reply #8 on: Tue, 21 October 2014, 12:06:54 »
Will be watching this later! Thanks for sharing.
Offline taylordcraig
« Reply #9 on: Tue, 21 October 2014, 12:32:07 »
A+ that was a great video to watch before I head in to work.
Very nice job and GREAT looking keyboard.
Offline jacobolus
« Reply #10 on: Tue, 21 October 2014, 21:53:15 »
Matt3o: do you have a wire stripper tool? If not, I recommend it. Instead of scraping sections of wire insulation off with a utility knife, you can just scoot the insulation along with the wire stripper; takes only a few seconds to prepare each of those columns that way.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #11 on: Wed, 22 October 2014, 00:16:35 »
Matt3o:  Out of curiosity, what gauge wire are you using?
Offline frosty
  • jukebox hero
« Reply #12 on: Wed, 22 October 2014, 00:20:11 »
Yup, would like to know too.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #13 on: Wed, 22 October 2014, 01:30:12 »
the black one is the thickest, 0.6mm so I can bend it easily. The color ribbon I don't know exactly, I believe it's a standard size, in the 0.4mm range.
Offline p3lim
« Reply #14 on: Wed, 22 October 2014, 05:01:01 »
Was gonna say the same, using a scalpel like that is really bad, wire strippers don't usually cost that much.
Other than that, nice job, I read through most of your topic on DT too, enjoyed it very much.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #15 on: Wed, 22 October 2014, 05:16:15 »
no I don't have a wire stripper. I tried one (borrowed) but it wasn't working very well with multiple cuts and such short wires. it really doesn't take that much to manually peel the wires with a scalpel.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #16 on: Wed, 22 October 2014, 08:04:07 »
holy crap that's awesome.
the music as well :D
mind me asking what spring are you swapping out for the stock blue ones ? does it make it stiffer or softer ?
thanks :D
Offline LechnerDE
« Reply #17 on: Wed, 22 October 2014, 08:17:10 »
Thanks for sharing! Can't view the video at work, but will do so when I am back home :)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #18 on: Wed, 22 October 2014, 08:25:26 »
thanks :D
ghetto green. black springs on cherry mx blue
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #19 on: Wed, 22 October 2014, 08:41:49 »
Need to get around to watching this tonight.
Offline jacobolus
« Reply #20 on: Wed, 22 October 2014, 13:35:57 »
Hand wiring inspiration:
