Author Topic: CM Storm Novatouch Tour (Tour Over)  (Read 139061 times)
Offline Hypersphere
Re: CM Storm Novatouch Tour (Tour in Progress)
« Reply #400 on: Fri, 23 October 2015, 20:01:25 »
@abjr: Thanks for the review. I agree with you about the coating and to some extent about the lack of a CapsLock LED.
However, regarding the connector, I have become accustomed to using 60% boards that usually have a flush-mount mini-USB connector on the rear of the case, although it is usually on the left (as you face the keyboard) or near the center. Because I swap out keyboards fairly frequently, I don't want to have cable routing, and I find it difficult to connect and disconnect the cable from a recessed area on the underside of the keyboard.
Therefore, I found it refreshing when using the Novatouch to have the connector easily accessible on the rear of the case and not having to undo the cable routing when switching out keyboards. Nevertheless, I understand that many people apparently really like to have the connector on the underside of the case with cable routing.
I understand CM's rationale for choosing a micro-USB connector (it is supposedly longer-lived than a mini-USB connector), but because most of my keyboards use mini-USB, I needed to keep a micro-USB cable handy when connecting the Novatouch. On balance, though, I like CM's choice of connector and its location on the keyboard.
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #401 on: Sun, 25 October 2015, 20:33:25 »
I literally just bought one. :X
« Reply #402 on: Mon, 02 November 2015, 07:21:59 »
Board is in heedpantsnow's hands right now.
Offline heedpantsnow
  • Old enough to know better
« Reply #403 on: Mon, 02 November 2015, 09:38:36 »
Board is in heedpantsnow's hot little hands right now.
FTFY
I'm back.
Re: CM Storm Novatouch Tour (Tour Ended - Restart in 2016)
« Reply #404 on: Thu, 19 November 2015, 06:48:01 »
The board arrived back at my home a few days ago. I'm going to look over what's in there and then the tour will go on a break until after the holidays when I'll restart it with some new stuff. Thanks to everyone for generally being great participants. There were only a few issues. Also if you haven't put your thoughts or a review up, please do so. Thanks.
« Reply #405 on: Thu, 19 November 2015, 13:50:36 »
Do I review here or in reviews section?
I'm back.
« Reply #406 on: Mon, 23 November 2015, 08:46:48 »
Wherever you want.
