Author Topic: Snapped Topre Stem  (Read 3477 times)
Offline Premonition
  • HHKB Elite
Snapped Topre Stem
« on: Thu, 23 October 2014, 10:58:14 »
So, I dun goofed pretty hard; didn't have a keycap puller with me, so I tried to pull of the Tab keycap on my HHKB with a pen, and half the stem cracked right off. It still goes in fine, wobbles a fair bit, but nothing crazy. Is it possible to glue the piece back on, by any chance?
Re: Snapped Topre Stem
« Reply #1 on: Thu, 23 October 2014, 11:00:34 »
A picture would help the diagnosis tremendously.
Offline Belfong
« Reply #2 on: Thu, 23 October 2014, 11:57:08 »
See, this is my fear even with a keycap puller when pulling the space bar! I usually took the left and right off the stabilizer, then use two hands to pull them off the middle switch but I still get nervous all the time!!!
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #3 on: Thu, 23 October 2014, 12:09:49 »
I should have a couple spare topre sliders once I swap with a novatouch (again) if it's too much of a problem.
You might be able to use some CA glue and an activator spray to repair that slider, too.
Offline Premonition
  • HHKB Elite
« Reply #4 on: Thu, 23 October 2014, 12:19:40 »
Alrighty, thanks for that. I'll try and see how it goes!
Offline oscillik
    • music podcasts
« Reply #5 on: Thu, 23 October 2014, 12:39:59 »
That shouldn't happen with the spacebar - the reason it shouldn't is because the Topre spacebar is ABS, while the other keycaps are PBT and much more brittle.
In fact, I think this may explain why we haven't seen a PBT spacebar for Topre...
I don't think it's the slider that's broken, it sounds like it's the stem on the keycap that has broken.
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline Xowie
  • On Sabbatical
« Reply #6 on: Thu, 23 October 2014, 12:45:11 »
Were you able to remove the broken stem from the slider? If so, you could use plastic cement (such as:http://www.amazon.com/Tamiya-87038-Extra-Thin-Cement/dp/B000BMYWYC/) and then sand down any seams to make it flush.
RETIRED
Offline Premonition
  • HHKB Elite
« Reply #7 on: Thu, 23 October 2014, 15:22:42 »
I see, thanks for the advice. It actually popped out with the keycap, so I'll attempt to use some cement to put it back. Much appreciated!
