Author Topic: Filco Printing  (Read 3220 times)
Offline Manyak
Filco Printing
« on: Mon, 06 July 2009, 06:39:01 »
Quick question: What kind of printing is used for Filco's lettering?
Currently Owned:
Filco FKBN104MC/EB - Model M 1390131 \'86 - Model M 1391401 NIB - Unicomp Endurapro NIB - iRocks KR-6230 - Compaq MX-11800 - Cherry G80-8113HRBUS-2 - Cherry ML-4100 - Cherry MY-8000-something - Dell AT101W (Black) - ABS M1 - Siig Minitouch - Chicony KB-5181 w/ SMK Montereys - Chicony KB-5181 w/ SMK Montereys NIB - Cherry G80-3494LYCUS-2 - Deck Legend
Offline Manyak
Filco Printing
« Reply #1 on: Mon, 06 July 2009, 17:37:59 »
Super duper sauce? lol
Currently Owned:
Offline takasta
Filco Printing
« Reply #2 on: Mon, 06 July 2009, 18:44:50 »
I always thought it was laser etching, cause the letters on the boards don't seem to fade, the keys itself seem to be smoothed out.
Cherry MX Blue DAS III, FKBN87MC/CB
Cherry MX Brown FKB104M/EB
Topre Capacitative Realforce UB103
Offline talis
Filco Printing
« Reply #3 on: Mon, 06 July 2009, 19:10:15 »
Its likely just pad printing or something similar.
The only way to get white text on a black key using laser etching is if you mold the key either out of two layers of plastic, or out of white plastic then paint it black before etching away to the white underneath.
You can get black text on a white key using laser etching a lot easier.
« Last Edit: Mon, 06 July 2009, 19:16:31 by talis »
Offline skyian
Filco Printing
« Reply #4 on: Tue, 07 July 2009, 05:57:56 »
Most of the filco keycap printing is silk printing which is a very common used printing way. To avoid fading of the letters, Filco put another "COATING" on the top of the keycap. Hence the touch of the keycap is more smooth than other company's keycap.
However, there're some of the Filco keyboards are made with laser keycap, for example, as far as I could remember, Filco Bluetooth keyboard(made by Datatcomp) and the newly released Filco white 104 keys keyboard, US Layout are both made with laser keycap.
My Own Keyboards:
RF 103 SILENT 30g, RF RGB, RF103black, RF103white, RF87UB, RF87WB, RF101, HHKB PRO2, Cherry with white, blue, brown, black, RED swithces...etc
WAITING FOR THE Ultimate Bluetooth converter for any keyboard.  Also the Beautiful GMK CAMPING Keycap.
Offline lowpoly
Filco Printing
« Reply #5 on: Tue, 07 July 2009, 06:05:36 »
Quote from: talis;101450
Black Cherry POM keycaps are different. It looks as if space for the symbol is lasered away and the remaining cavity (?) is filled with white plastic.
Offline itlnstln
Filco Printing
« Reply #6 on: Tue, 07 July 2009, 07:36:17 »
Quote from: lowpoly;101500
While not the prettiest looking keycaps, I like the Cherry POM keycaps.  They are very durable, but the text on the legends looks blurry xusing their process (at lest on my 'board).
Offline lowpoly
Filco Printing
« Reply #7 on: Tue, 07 July 2009, 08:08:59 »
Mine are not blurry. But the white plastic seems to be more solid in the middle of a line. And a little bit transparent at the edges.
We might be talking about the same thing.
Offline itlnstln
Filco Printing
« Reply #8 on: Tue, 07 July 2009, 08:14:16 »
Quote from: lowpoly;101510
"Blurry" was probably not the best description.  Yours is much more precise.  "Soft" is probably a better description.
Offline talis
Filco Printing
« Reply #9 on: Tue, 07 July 2009, 09:13:28 »
They could possibly laser sinter white plastic as well (apply a thin layer of white plastic powder, then melt it with a laser).
