Author Topic: Is it possible to Vinyl Wrap a Keyboard plate with switches on it  (Read 2390 times)
Offline Owntrolf
Im thinking of doing this so the backlight looks even brighter like how they do it on the Razer Chroma
« Last Edit: Fri, 24 October 2014, 20:14:04 by Owntrolf »
Offline Oobly
Re: Is it possible to Vinyl Wrap a Keyboard plate with switches on it
« Reply #1 on: Sat, 25 October 2014, 14:57:37 »
You could try spraying white PlastiDip on there with the switch stems masked off.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline corydora
« Reply #2 on: Sun, 26 October 2014, 09:24:35 »
I've been wondering this - I don't trust my soldering skills to remove/replace the switches, and am a bit wary of painting the plate with the switches in situ. The current plan is to make a paper template using strips of paper taped together between all the switches, and then use that template to cut the vinyl to size. Worst that can happen is I waste a piece of vinyl. I can take potato pics of the progress if you like and let you know how it turns out.
« Last Edit: Sun, 26 October 2014, 09:32:14 by corydora »
Offline Oobly
« Reply #3 on: Sun, 26 October 2014, 15:18:15 »
PlastiDip isn't like spraypaint, though, you can peel it off / rub it off pretty easily. The vinyl would probably be more work, but I don't see any reason not to give it a try. Please post a pic if you do.
Offline corydora
« Reply #4 on: Sun, 26 October 2014, 16:56:53 »
The vinyl I have is this really nice satin/matte finish metallic tho, so nothing I could find in plastidip.
Offline Owntrolf
« Reply #5 on: Sun, 26 October 2014, 17:29:10 »
I have no idea what vinyl I should order :p matte or carbon fiber finish
