Author Topic: What's the "click depth" of the Filco Zero tenkeyless?  (Read 1256 times)
Offline Bwappo
« on: Tue, 07 July 2009, 20:15:19 »
Heya all. First off, thank you all for the tremendous amount of information and insight you have here. In my quest to find a keyboard similar to one I loved many years ago, I learned more from geekhack than I ever thought there was to know about keyboards.
My "click depth" question will make sense in a moment -- hang in there. I like my old IBM model M, but it's a tad too strong on resistance for me. While searching for the same click but less resistance, I bought and tried the Scorpius M10 to get a feel for the blue cherries. Besides the fact that the Scorpius I received had a defect, the keys were too weak, and the "click depth" was too high.
Meaning, if I were to press on the key in slow motion, about 40% of the way down I encounter the click on the Scorpius M10, then I have 60% of key travel remaining before I bottom out. On the model M, I find the opposite: 60% travel until click, then 40% remaining until bottoming out.
From what I read of various experiences on this site, it sounds like the ...is it the fake white alps? ...of the Filco Zero Tenkeyless might have the resistance strength I'm looking for: stronger than any of the cherries, but not quite as strong as the bucking switches of the IBM M series. If that's true, I would love to hear from you if you have this particular keyboard and could tell me roughly how far down you press the key before it "clicks".
Thanks again!
Bwappo
Offline kyamei
« Reply #1 on: Tue, 07 July 2009, 20:26:25 »
The click is even higher.  If blue Cherries is 40%, white Alps are something like 20%.
Edit:  The click is higher on the stroke, but the stroke itself is shorter so that percentage is off.
« Last Edit: Tue, 07 July 2009, 20:29:05 by kyamei »
Topre:  Realforce 101, Realforce 87U, HHKB Pro 2
Cherry Brown:  Compaq MX11800
Cherry Blue:  Filco FKBN87MC/EB
Cherry Black:  K-202 numerical keypad
Alps Black:  AT101W, ABS M1
Alps White:  Focus FK-2001
Buckling Springs:  Model M 1391401, Lexmark Model M 82G2383, Model M2
Buckling Sleeves:  Unicomp Model M4
Futaba:  Sejin EAT-1010
Offline Bwappo
« Reply #2 on: Tue, 07 July 2009, 21:39:29 »
Gah. Well, thank you for saving me $80 + shipping. That's disappointing to hear the click depth is so high.
What would you all recommend for a low click depth, high resistance keyboard, other than the old school IBM model Ms?
Bwappo
