Author Topic: Budget mx brown keyboard  (Read 1904 times)
Offline neverused
« on: Sun, 26 October 2014, 12:28:27 »
Hello,
I was wondering if anyone has a suggestion for a good ten-key keyboard with mx brown switches? My budget isn't large, perhaps around $100 but backlighting would be great and worth extra.
Thanks for your help!
Offline Rotaku
  • Too Based
Re: Budget mx brown keyboard
« Reply #1 on: Sun, 26 October 2014, 12:32:53 »
If you want backlighting you could go with the ducky zero shine http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=898 but if you want to save about $30 and don't need backlighting, the cm storm quickfire rapid would work too
Not toooo active on GH anymore, if you need me, shoot me a PM on Reddit! /u/IchibanXD
Offline Flyersfan1
  • Hi!
« Reply #2 on: Sun, 26 October 2014, 12:33:53 »
If you can forgo backlighting, the Quickfire Rapid can be had for ~$90 on Amazon at the moment.  http://www.amazon.com/Storm-QuickFire-Rapid-Tenkeyless-Mechanical/dp/B0068INSUM/ref=sr_1_1?ie=UTF8&qid=1414344602&sr=8-1&keywords=qfr-i
If you're really set on backlighting though, I would recommend this..but it's slightly over your budget.
http://www.mechanicalkeyboards.com/shop/index.php?l=product_detail&p=898
Quote from: Photekq
Offline neverused
« Reply #3 on: Sun, 26 October 2014, 13:01:44 »
Thank you for the quick replies, are there any suggestions for keyboards with the ten-key keypad?
Offline user 18
« Reply #4 on: Sun, 26 October 2014, 13:03:48 »
For full size backlit boards, Ducky Shine series is still a good pick, as is Max Keyboards Nighthawk series.
If you want a cheaper option, you could look at some of the full-size Cooler Master boards.
Avatar by ashdenej
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Sun, 26 October 2014, 13:50:57 »
If you don't mind the magstipe reader... Cherry G80-8200HPBUS are a great deal. Has best doubleshot keycap that is worth more than backlighting any time.
Offline winged mantis
« Reply #6 on: Sun, 26 October 2014, 16:34:15 »
The Rosewill RK-9000BR is decent
Offline Oobly
« Reply #7 on: Mon, 27 October 2014, 03:53:58 »
Ducky Shine Zero.
CMStorm Quickfire XT.
Both full size, Shine Zero has backlighting Quickfire XT doesn't. They're both very good value for money and have completely standard layout, so any keycap sets will fit.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline julayyy
« Reply #8 on: Mon, 27 October 2014, 14:15:04 »
CM Storm Quickfire TK has a numpad in a TKL form factor and is fully back lit. The back light color correspond with the switch type except for brown = white LED.
they should be around $80-90 on Amazon I think.
The only downside of this keyboard is that if you're into modding your key caps, the TK has a nonstandard bottom row so you might have trouble finding the right key cap for it.
« Last Edit: Mon, 27 October 2014, 14:17:40 by julayyy »
QuickfireTK MX Reds         v60 mini MX Clears
