Author Topic: Magnetic Switches  (Read 3172 times)
Offline byker
  • Literally Canada
Magnetic Switches
« on: Mon, 27 October 2014, 00:28:13 »
Anyone see this guy's post over at /r/mk? https://www.reddit.com/r/MechanicalKeyboards/comments/2keuyy/modification_cherry_mmx_swap_your_springs_for/
Looks pretty interesting to me! He says they are softer than reds, but extremely hard to bottom out, which makes sense!  :p
Re: Magnetic Switches
« Reply #1 on: Mon, 27 October 2014, 00:40:27 »
I saw them, but felt dirty linking there.  Definitely an interesting concept.  I'd imagine the "bottoming out" wouldn't feel that great. It may be something I give a try in the future.
Now what would be really interesting (and probably totally not feasible) would be making a switch with an electromagnet in it so that you could adjust the weight of the switch to your own personal taste.
Offline byker
  • Literally Canada
« Reply #2 on: Mon, 27 October 2014, 00:42:17 »
Yeah, I was going to just link to the imgur album, but thought people might want to see the whole thread.
It is definitely a cool idea, should be cool to see where this goes, that would be cool if you could adjust the weight easily!
Offline Ripudio
« Reply #3 on: Mon, 27 October 2014, 01:13:36 »
I am definitely going to try this with any left over switches I have, awesome idea!
« Reply #4 on: Mon, 27 October 2014, 10:11:09 »
I'm really not sure about the exponential force curve but it's really interesting!
Offline jacobolus
« Reply #5 on: Mon, 27 October 2014, 18:03:01 »
It’s possible the force curve could be adjusted using a printed magnet:
http://www.correlatedmagnetics.com/video-gallery/
« Reply #6 on: Mon, 27 October 2014, 19:34:03 »
Great idea, but would all those little magnetic forces be completely harmless to all the electronics in the vicinity, long-term?
- D Trump 2026-10-24
Offline JinDesu
« Reply #7 on: Mon, 27 October 2014, 19:55:27 »
The magnetic flux field doesn't extend that far, so given the small magnets involved, they would be sufficiently insulated from the electronics.
I would love to get a few and try, if the guy was to produce them in large quantities - but seems like he hand makes them so that'd be unlikely.
Someday somebody will best me, but it won't be today, and it won't be you.
Proud owner of a Filco Majestouch Cherry MX Blue Tenkeyless, KBT Race S, & Realforce 101
« Reply #8 on: Mon, 27 October 2014, 20:58:53 »
Whoa! So what do you do, make a tube and cut it into tiny slices?
Offline epicepee
« Reply #9 on: Fri, 31 October 2014, 15:55:37 »
I think they meant he hand-modifies the switches.  The magnets are standard and can be bought online.
« Reply #10 on: Fri, 31 October 2014, 16:14:07 »
he drilled out the post that holds the stem in place and put one magnet there. The other has to be glued to the stem. They are probably a little more wobbly afterwards but (hopefully) not much.
