Author Topic: 1390131 chassis in beige?  (Read 2179 times)
Offline lowpoly
« on: Wed, 08 July 2009, 05:42:08 »
Is this common? Never seen one of these before in beige. But I don't have that many Ms. It's from an 1390131-like board which I got for parts. Not sure if the gray stems are original, as keycaps were missing or relocated.
« Last Edit: Wed, 08 July 2009, 05:55:06 by lowpoly »
Offline ch_123
« Reply #1 on: Wed, 08 July 2009, 07:14:25 »
Somewhat unrelated, but what's the model number of this German 1390131?
Offline lowpoly
« Reply #2 on: Wed, 08 July 2009, 08:05:35 »
Here's the label:
Offline lowpoly
« Reply #3 on: Wed, 08 July 2009, 09:09:04 »
Ah, thanks.
Offline lowpoly
« Reply #4 on: Wed, 08 July 2009, 09:38:34 »
The green dot is everything.
Unrelated, this label is paper with an added protection film.
Found two ocurrences for the fcc id, both OEM models.
« Last Edit: Wed, 08 July 2009, 09:41:25 by lowpoly »
Offline Hak Foo
  • Make America Clicky Again!
« Reply #5 on: Wed, 08 July 2009, 09:59:37 »
My '90 1391401 is beige on the inside.  I found it odd too.
Overton130, Box Pale Blues.
Offline lowpoly
« Reply #6 on: Wed, 08 July 2009, 10:10:04 »
I wonder if the stem color is supposed to match the cap color on the two-piece keys. It was like that on mine but there are not enough gray stems.
Offline lowpoly
« Reply #7 on: Wed, 08 July 2009, 10:18:18 »
Gray stems with ivory for F and J is what I've seen so far on other boards. Must be some production thing. "Nipples go here!"
Offline talis
« Reply #8 on: Thu, 09 July 2009, 00:05:06 »
My '89 1391401 has the same beige key tray.  It came with about 95% dark key stems, and a few light.  Its always hard tell if the keys are transplant or not tho.
Offline lowpoly
« Reply #9 on: Thu, 09 July 2009, 08:34:22 »
I fail to see a pattern with either the stems or the chassis colors.
