Author Topic: Calling all Poker II owner (LED state issue)  (Read 2015 times)
Offline Hogesyx
« on: Mon, 27 October 2014, 23:27:59 »
Hello all fellow Poker II owner, just a quick question as for some reason my Poker II(LED mod) no longer save LED state after a recent reset(fn+r), tested across different PC and seems to have the same result. I downgraded to the other firmware version from the "firmware update" and it does not seems to solve the problem.
Posted on reddit and seems that there is another guy who thought this was the normal behaviour.
So fellow GH, is your Poker II:
- Able to save LED state(across power cycle/unplug replug)?
- Stock LED or PBT mod LED?
- Reset before?
edit: This is my first post on geekhack! Been a silent reader for years but this is my first time posting.
« Last Edit: Tue, 28 October 2014, 21:47:22 by Caekys »
Novatouch TKL | Ducky YOTR (Brown) | Ducky Shine (Brown)
Poker II (Red) | GH60 revchn (Clear)
Offline Demetrium
Re: Calling all Poker II owner (LED state issue)
« Reply #1 on: Tue, 28 October 2014, 15:47:45 »
I recently got a Poker II but haven't had the opportunity to play with it much. Can you elaborate on what you mean by saving the LED state? Do you mean that it doesn't retain the LED brightness level/on/off when you unplug the keyboard and plug it back in?
I might be able to test whatever you like tomorrow when I get home.
Offline Hogesyx
« Reply #2 on: Tue, 28 October 2014, 21:47:59 »
Yep, either power cycle or replug.
Offline iqbal_kakashi
« Reply #3 on: Tue, 28 October 2014, 21:51:10 »
Mine won't save the LED state since I got it. I don't use the LED very much though. :D
Offline kohi
« Reply #4 on: Wed, 29 October 2014, 00:42:55 »
I have a poker II with stock LEDs and I've never gotten it to save LED state. I tried it out before reset and after reset
Offline Hogesyx
« Reply #5 on: Wed, 29 October 2014, 03:10:26 »
Oh dear, I am not sure if I am hallucinating or not any more.  :-[
Most of the guys that I ask online seems to have the same issue as me, only a contact of mine that mention he dont recall having to retoggle the LED mode every power cycle on his old Poker II that he sold away.
